Old 09-29-2015, 10:50 PM   #1
Fredthecat
Speedometer repair parts
Where can I purchase the plastic gear/shaft that turns odometer number wheels?
White plastic shaft, 2 3/4" long, spiral gear at one end, worm gear at other.
Mine is broken at middle of worm gear.
1964 C10, 00000.0 miles
Thanks,
Fredthecat
Fredthecat is offline   Reply With Quote
Old 09-30-2015, 01:50 AM   #2
Fredthecat
Odometer repair parts
The odometer gear needed:
2 3/4" end to end
7 turns worm gear
11 spline spiral gear
What other Chevy cars/trucks use same? Sources?
Thanks, Fredthecat
Old 09-30-2015, 02:03 AM   #3
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Speedometer repair parts
I should be able to help you. Just an FYI, The 64-66 chevy truck speedometer frames are unique and parts do not interchange from other makes and years like the other GM speedometer frames.
You need to also check your odometer drum and make sure it is not froze up which is the # 1 cause of these gear failures inside the speedometer frame.
Send me a PM with your needs.
Thank you,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
