1969 chevy cst big block
Can anyone tell me if the 1969 Chevrolet CST big block trucks were labeled with the 400 badges? I read that the later models were labeled with the 400 badges and wanted to know if this is the case. Any insight would be greatly appreciated...
![]() Join Date: Jan 2007
Re: 1969 chevy cst big block
pretty sure it should have been badged as 396 in 1969.
I live in California, but identify as a Texan ![]() "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
Thanks for the reply... I will keep researching. I heard that the some of the later models in 1969 could of been labeled with 400 fender badges.
Roadtrip!
![]() Join Date: Feb 2003
I believe this is correct...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
![]() Join Date: Feb 2009
The 402 was introduced in 1970.
GM was developing the SBC 400, but didn't want a SBC with a larger CU, so they punched out the 396 to 402, and slapped on a 400 emblem to test our limits. Course that wasn't enough, so on some they slapped on the 400 emblem, SPID read 396, and featured a 402 under the hood, and/or any variation of the three. Make sense?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-03-2015 at 02:42 AM. |
#7 | |
#8 | |
Once upon a time, I thought I heard the 396 heads had larger ports and therefore more compression. If I recall, it was 10:1 Vs 8.5/1. The heads on my rebuild came off a 396. Note: I don't know a lot about engines. I just did the R and R, with my buddy who led.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#9 | |
I see. Thank you.
Yes it does.. I am buying this truck and am in the process of verifying it has the number matching motor. I have not seen to many at all with the 400 badge but did read on line that they did label some of the later 69 models with the 400 badge. Can't wait to get it bought
Thanks for your reply Byronl68 1966 shortbed Big Window A/C truck 1961 Chevy K10 Shortbed fleet side 1962 Chevy K10 Shortbed step side |
Always thought the 402 started in 1971?
Nope, 1970...........
Big-Block Chevy: Block Casting Identification Casting No.: Designation: Model year: Notes: 3999290 396 '68-'69 two- or four-bolt, truck 3999290 402 '70-'72 two- or four-bolt, truck
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-07-2015 at 03:52 PM. |
Thanks for all the input. Im excited to get the truck and appreciate your help in verifying it's correct. This truck is pretty cool. Does anyone know the correct engine code for a 1969 400 block and where on the engine I would find the code?
