10-04-2015, 09:00 PM | #1 |
At the body shop.
Master cylinder pushrod questions.
I am removing the vacuum booster and master cylinder,
Going for a manual brakes master cylinder. I know the pushrod is different, does anybody know how long of one I'll need.
" That didnt make it any newer " " Dont antique the equipment " |
10-05-2015, 12:45 AM | #2 |
Re: Master cylinder pushrod questions.
I have a hydraulic clutch pedal setup with manual brakes sitting in my garage. I can take a measurement for you. Does the manual brake pedal take a different size pin for the pushrod than the power brake pedal?
10-05-2015, 12:48 AM | #3 |
At the body shop.
I haven't taken it apart yet, waiting for the master cylinder to show up.
Was trying to collect parts up before I pull it apart.
10-05-2015, 12:50 AM | #4 |
Ok. Pretty sure it is. Check post #3 in this thread
http://67-72chevytrucks.com/vboard/s...d.php?t=527532 |
10-05-2015, 01:33 AM | #5 |
At the body shop.
Yeah, I read that one while searching the board.
I was looking for a length, wondering if this will work. http://www.mpbrakes.com/gm-adjustabl...ame=&limit=100
10-09-2015, 10:11 PM | #6 |
At the body shop.
How do I remove the push rod from the brake booster?
10-09-2015, 11:55 PM | #7 |
You shouldnt have to. There is a pushrod on the pedal that pushes into the booster against a second pushrod if I remember right.
Anthony |
10-10-2015, 12:53 AM | #8 |
At the body shop.
Between the pedal and booster, I pulled the booster and master. And can't seem to get the pushrod out of the booster.
10-10-2015, 12:57 AM | #9 |
Take the pin out of the brake pedal. Should unscrew? Been a while since I had a system off.
Anthony |
10-10-2015, 01:08 AM | #10 |
At the body shop.
The back half did, the front half or booster side feels like a clip or something.
But I'm understanding the power brake pushrod would be to short for a manual master cylinder, so the hunt continues.
10-10-2015, 03:58 PM | #11 |
At the body shop.
Score! 1st truck at the pick N pull was a manual brakes.
Got the pushrod now to bleed the mess..
10-10-2015, 10:48 PM | #12 |
At the body shop.
It bled easy, has a great pedal.
The offending part. Can't wait to drive it.
10-16-2015, 07:04 PM | #13 |
10-16-2015, 08:10 PM | #14 |
At the body shop.
That's the manual brake master cylinder push rod.
Found one in the 1st truck at the pick n pull.
