Old 10-06-2015, 11:35 AM   #1
byates2
byates2's Avatar
Hood Latch Issues 67
I just started putting the body back on my 67. The fenders, the cowl, the rad support and the grill went on without much issue. Everything lined up (with some pulling and brute force) pretty evenly. However, I bought a hood latch off Ebay, an original off a 67 and the damn thing doesn't line up with the bolt holes on the grill. The latch is too long. I'd say probably an inch off from the mount holes. This also happened with a latch I mistakenly bought for a 69.
The truck was in an accident and had to have the frame straightened. I am worried this might be an issue of "trueness" in the frame and the body, but everything else lines up so i don't know about that. The grill is off a different truck and one of the fenders is a repro. Both fender skirts are also repro.
Is there a trick to this, am I missing something? I notice that sometimes there were parts for "early" 67's and later model 67's and mine is an "early" 67 which has caused issues before with part fitment. I am wondering if this may be the case? Anyone have any experience with this? What is the correct length between the rad support and the grill mount holes? Maybe I just bought an incorrect part again, but I dont think that is the case.
Thanks in advance
1967 C10 Long Bed, Soon to have a 350
1997 Chevy 2500 454 BB
byates2 is offline   Reply With Quote
Old 10-06-2015, 11:38 AM   #2
byates2
byates2's Avatar
Re: Hood Latch Issues 67
here is the link to the itemhttp://www.ebay.com/itm/201422665054
Old 10-06-2015, 11:48 AM   #3
michael bustamante
michael bustamante's Avatar
can you post a pic of the hood latch you are using? are you still using a 67 radiator support? and grill retainer?
so you know the 67 chevy and the 67 GMC hood latches are completley different, you might want to make sure its a chevy hoodlatch
I just looked at the listing. that shiny black one and the old rusty one in the other listing its linked to look a little bit different, the handle seems longer on the shiny one. the rusty one looks like mine on my 67
1967custom
michael bustamante is offline   Reply With Quote
Old 10-06-2015, 12:30 PM   #4
byates2
byates2's Avatar
By grill retainer, do you mean the piece that goes in between the grill and the rad support? If so, i have the original but i have not put it in yet, i forgot about that. But i dont think that will make a difference because of how off the latch mount holes are.
I am using a repro 67 rad support. I do not have a hood latch that i am using, i must of thrown the original one away or it may have been damaged in the accident, i dont remember.
I didnt see any rusty one that is linked to that listing.
Old 10-06-2015, 01:22 PM   #5
michael bustamante
i can take measurements and send you pics of mine tonight if you like, just contact me tonight after 5 mountain time. 505-907-6836
1967custom
Old 10-06-2015, 01:29 PM   #6
byates2
byates2's Avatar
That be great. I'll send you a text. thanks
Old 10-06-2015, 03:14 PM   #7
byates2
byates2's Avatar
Nobody else has any ideas?
Old 10-12-2015, 08:47 PM   #8
Fitz
The grill retainer has to be installed to get even close to the correct spacing for the latch. Without that in, the latch will not go in correctly. The angle braces that tie the top of the core support and the grill bolts that attach the grill to the fenders may need to be loosened to get the latch in. I can remember fiddling with mine for an entire day just to get that in so the latch would operate correctly. Take your time. It actually will fit in when the front is aligned correctly.
Fitz is offline   Reply With Quote
Old 10-06-2015, 03:30 PM   #9
67chevemall
67chevemall's Avatar
http://www.ebay.com/itm/201422665054?rmvSB=true
The the OEM latch on the page for $40.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 10-06-2015, 03:52 PM   #10
byates2
byates2's Avatar
I dont know what latch you are referring to. It links to the page of the item i bought, but i do not see an oem latch for 40
The latch i bought is supposed to be OEM and off a 67
Old 10-12-2015, 07:23 PM   #11
byates2
byates2's Avatar
Nobody has any ideas or thoughts on the matter?
Old 10-12-2015, 07:32 PM   #12
Robznob11
Robznob11's Avatar
I had the same problem on mine you wouldn't think so but the grill will flatten out . Loosen it at the fenders, and the fenders as well. Bolt the latch in then button up the fenders. I bet if you leave it off your gaps at the front of hood and fender are a little wide and the peak of the grill is not as pointy as the hood peak. I figured mine just did it because I cut the center bar out.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 10-12-2015, 09:45 PM   #13
The center support (grille retainer) goes in before the hood latch. Put that in and get back to us. All hood latches interchange, meaning they bolt up the same. There are differences for other reasons, but one will bolt-in where the other goes. You could also post a picture of yours and I'll tell you if it is correct for '67 Chevy. There are 67/68 GMC, 69-72 GMC, 67/68 Chevy, 69/70 Chevy, and 71/72 Chevy latches. All '67s slope in the front and all 69-72 are steeper, just like the hoods. All other differences are for the grille
Old 10-13-2015, 09:00 AM   #14
byates2
byates2's Avatar
Thanks! I haven't put that center piece in. I'll try that and loosen the grill bolts and see if i can muscle it in. Was just hoping it was an easy bolt in haha... nothing comes easy on these old guys
Old 10-13-2015, 03:36 PM   #15
67chevemall
They are the easiest vehicle on the planet to work on. Take your time
You are over thinking it and not working in order of procedures.
Good luck have a beer first!
