Old 10-09-2015, 01:23 PM   #1
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
CPP vs Captain's Power Steering Adapter Plate.
I've been seeing threads/posts of those who used the CPP Adapter Plate and wondered why their plate always mounts the box out of tilt.
http://67-72chevytrucks.com/vboard/s...d.php?t=602412
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 10-09-2015, 01:25 PM   #2
LostMy65
LostMy65's Avatar
Re: CPP vs Captain's Power Steering Adapter Plate.
Here is how much out of tilt the CPP Adapter Plate is.
Old 10-09-2015, 03:00 PM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Just a heads up to all, do not turn this into a vendor bashing thread.
Post up questions or useful info.
Thanks all.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 10-09-2015, 03:23 PM   #4
LostMy65
LostMy65's Avatar
Yes, my intent here is to show the advantages and/or disadvantages of one over the other.
I'll be posting more pics, but I see why CPP made their plate the way they did. They did it to simplify the alignment process. By using two of the existing holes, they prevent user errors. And as mentioned in the thread I linked above, the Rag joint takes up the variance.
Old 10-09-2015, 03:31 PM   #5
LostMy65
LostMy65's Avatar
Here is a pic of my frame marking the two different hole locations for the power steering box.
The circled holes are the two existing holes that CPP uses to locate where the plate goes. The little hole starters where I've marked with an asterisks is where the holes actually need to be located for the box to align with the steering shaft straight on.
Old 10-09-2015, 04:35 PM   #6
slepysal
slepysal's Avatar
When I did mine ( that's mine in the first picture) no one but CPP had anything for he 60-62 frames. Rez made one that required some modification for it to work on the 60-62. More work then I wanted to do.
To answer your question I believe CPP did it that way ,as you mentioned, for ease of install with tools that the average Joe would have. ( no welding)
I have had zero problems with the install and none it since installing it.
Captain fab makes outstanding products and if this was available back when I did mine I would have purchased it from him, not that the CPP one is bad. I just like the fact that the Captain is hands on.
Hope this helps
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 10-16-2015, 06:40 PM   #7
LostMy65
LostMy65's Avatar
I finally got my power steering box mounted.
CPP goes the easy route by using two of the existing holes. I mounted mine keeping the steering shaft and pitman shaft aligned. But it's a total pain in the butt to do it that way on the 60-62 frames.
So, if you have the 63-66 frame, I recommend using Captainfab's plate.
But for the 60-62 frames, I recommend using the CPP kit. Only because they did it in such a way to make the install with the least amount of hassle.
What little it's off with alignment, can be taken up with the rag joint.
Old 03-22-2019, 07:07 PM   #8
demian5
demian5's Avatar
Is Captain Fabs a bolt on as well or do you need to mod the top of the frame and cut it?
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 03-22-2019, 11:39 PM   #9
LostMy65
LostMy65's Avatar
Are you working on a 60-62 or a 63-66?
Old 03-25-2019, 06:03 PM   #10
demian5
demian5's Avatar
Originally Posted by lostmy65 View Post
are you working on a 60-62 or a 63-66?
60-62
1986 C20 Scottsdale
Instagram: C10sofOC
Old 03-29-2019, 07:01 PM   #11
LostMy65
LostMy65's Avatar
It has been pointed out to me that Captainfab now has an adapter plate for the 60-62 trucks.
Sorry for my misinformation.
Originally Posted by Captainfab View Post
I do make a power steering box adapter plate kit for the '60-'62 frames. I just do not have installation instructions or a template for it yet. There are 3 threads here on the forum showing past customers' installations. One has some dimensions.
