10-09-2015, 07:36 PM | #1 |
BB PS Remote Res.w/ Extension arm?
Usually I go into the archives and find my answers. This time I haven't found what I'm searching for.
I have a 1972 402 BB. I added PS as the truck was never ordered with it. I'm also in the process of adding an auxiliary battery. I read somewhere that an EXTENSION ARM is required for the remote reservoir when an auxiliary battery is installed due to the additional junction block I assume. Is this true? If so, does anyone have a photo? I may need to find one.
A man's thoughts devise his ways; but it's GOD that directs his steps. Last edited by John Pasinski; 10-09-2015 at 08:13 PM. Reason: clarity |
10-09-2015, 07:55 PM | #2 |
Roadtrip!
Re: BB PS Remote Res.w/ Extension arm?
I think the 68s came with the extension or if you had the aux. battery. I can post up a pic later if no one else does.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
10-09-2015, 10:58 PM | #3 |
Member #1049
I do believe Eric is correct, I have only found them on 68's, not sure about the other years,
Here is the one on my 68 |
10-10-2015, 08:18 AM | #4 |
Livrat.....Would you post photos of the junction block locations, as well as the squirts reservoir location on your truck?
I'm trying to determine the locations of these items.
A man's thoughts devise his ways; but it's GOD that directs his steps. |
10-14-2015, 11:07 PM | #5 |
Member #1049
John,
For some reason I totally missed your reply asking for pictures, Sorry. Unfortunately my truck is a "Mutt", I installed the aux battery tray but never did wire up the relay and junction block. Here are a couple of pictures of my windshield squirter bottle mounting, again I just located it where it seemed to fit and not to any factory specs. |
10-15-2015, 06:03 AM | #6 | |
Although it appears the right side mount location uses a different bottle bracket. It looks like there's an "S" style modification to the right side bracket. Am I correct? Perhaps that style bracket is required to clear the inner fender?
10-15-2015, 11:18 AM | #7 |
Member #1049
Now that you mention it, it does appear to be a stock truck bracket with a modification, I do believe it is a factory GM bracket but I do not remember exactly what car/truck it came off of, Its one I had laying around, At the time I built the truck I had built/parted a bunch of 67-69 Camaros, 64-72 Chevelles, ElCamino's and 70-72 Monte Carlos.
Maybe someone that knows what it came off of will chime in? |
10-15-2015, 04:05 PM | #8 | |
Always on the hunt...
