Old 10-09-2015, 09:58 PM   #1
Birdman72
72 k10 gearing help
What size gear are you guys running with 35in tires. I have a 383 stroker with a 350 turbo trans. It's not used for off-road just a pavement pounder.
Birdman72 is offline   Reply With Quote
Old 10-10-2015, 08:18 AM   #2
b454rat
Re: 72 k10 gearing help
Id say 3.73s. Good compromise for acceleration and highway speeds.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 10-10-2015, 09:30 AM   #3
enigma
I would suggest 3.08, that is the combo I am going with but the difference is I will be going with 31's.
enigma is offline   Reply With Quote
Old 10-10-2015, 10:38 AM   #4
bmchevy1979
bmchevy1979's Avatar
Or 4.11 I run 3.73s on my k5 with 33s and it does fairly well out on the highway I'm not sure how much power you would loose with 35s though my truck will run freeway speeds no problem and has good power down low
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 10-11-2015, 08:13 PM   #5
Mike C
Mike C's Avatar
4.11's a re a great choice with 35's and a manual trans or tight converter. If you have a looser converter, consider 3.73. Or if you plan on some longer highway trips the 3.73 would also be a better choice.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-12-2015, 12:19 AM   #6
bmchevy1979
^ I agree my truck will run 70mph down the freeway happily but I wouldn't want to go much faster for long trips but I usually stay within 60 miles so it occasionally sees 80 have seen 110 but I probably won't push it that far again haven't needed to go that fast for any reason since
<Brandon>
