Old 10-10-2015, 08:24 PM   #1
gramps77
Caliper upgrade for Big 10
I realize the single piston is fairly large on my truck, but is there a dual piston replacement? Ive tried cking a few aftermarket places but not much available unless you do an absolute brake change over.
The brakes havent been touched or worried about in at least 5 years with no issues, but those 5 years are finally catching up. Rotors are wearing unevenly and pads need replaced soon. Id like to do front and rears all at once and be done with it
gramps77 is offline   Reply With Quote
Old 10-10-2015, 08:45 PM   #2
bmchevy1979
bmchevy1979's Avatar
Re: Caliper upgrade for Big 10
Wilwood makes them they aren't listed for a truck but they are the same caliper as the 71 elcamino I've done a lot of work same calipers and pads
pic from current summit catalog
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 10-10-2015, 09:50 PM   #3
gramps77
Those part numbers will bolt right up? no other input information for type of vehicle needed?
Old 10-11-2015, 01:45 AM   #4
bmchevy1979
I've used the pads for the elcamino on my truck and the calipers physically look the same so i would think they are the same the pads were a dead match and you have a big10 so you have 1 1/4" rotors I just checked summit and the SSBC ones say they work on a c10 but they only work on the lighter 1" rotors and 81-87 but that is just because of the brake line difference they actually do interchange to a 73-80 I'm sure the wilwoods will work plus they support the wider rotor and they are a little cheaper
<Brandon>
Old 10-12-2015, 09:41 PM   #5
tmoble
I never understood why these are marketed as direct replacement calipers. I'm sure Wilwood knows that 2 x 2" pistons do not give the same piston area as 1 x 2.94 pistons. You lose about 1/2 sq in of piston area. How does this affect braking on your vehicle is unknown. But, I'll bet that if people complain about braking performance they immediately come out with something like "You need to buy our new improved double razmatazz triple throwdown master cylinder to go with those calipers."
Been here before with Wilwood.....
tmoble is offline   Reply With Quote
Old 10-12-2015, 09:47 PM   #6
tmoble
if your pads are wearing unevenly it's likely because the slides are bound up. new oir cleaned up pins/bushings/o-rings plus clean-up of the surfaces where the calipers ride against the spindles probably fix it.
Did I mention that Wilwood calipers do this too?
Old 10-12-2015, 10:59 PM   #7
nonstop
Have you thought about throwing on c20 calipers? I believe they are a direct bolt on and could be had with 3 5/32 inch pistons and cost $10 each plus core from rockauto. Might be cheap enough to be worth a try before dropping more money on Wilwood calipers.
nonstop is offline   Reply With Quote
Old 10-13-2015, 09:26 PM   #8
Aaron_L
I have these for my truck. They are a bolt-on and cheap. I haven't ran them yet, but thousands of c20's can't be wrong, lol. I bought mine from O'reillys.
Aaron_L is offline   Reply With Quote
Old 10-13-2015, 05:16 PM   #9
tmoble
recommend against changing the diameter of the piston unless you're prepared to make other changes to match
