Old 10-14-2015, 07:21 PM   #1
GreenBay1921
GreenBay1921's Avatar
3 Speed transmission (3 on the tree)
I have a 1968 swb with a Muncie 3 speed. The truck had been sitting for 25 years before I got it. It shifted fine, but was roar like a beast. When I drained the transmission, it had a good 10-12 oz. of crystal clear water in it. When I cracked it open it has a good bit of pitting on the tip of the main shaft & most of the gears. That being said, I'm pretty sure I need to scrap it. I'm looking to keep the 3 on the tree, so I've been looking for a replacement. My question is: will a Saginaw work, & if so, will I need to replace shift linkage. It looks like the linkage where it connect to the transmission is different from the Muncie to the Saginaw. Do you guys have any suggestions about my situation? Thanks guys.
'68 Chevy C10
'06 Saleen Mustang #725 (Convertible)
'04 Infiniti G35
'01 Infiniti QX4
GreenBay1921 is offline   Reply With Quote
Old 10-14-2015, 07:24 PM   #2
EARNHARDT#3
EARNHARDT#3's Avatar
Re: 3 Speed transmission (3 on the tree)
Not sure about the linkage. The Saginaw is a little longer so you'll need to either have your driveshaft shortened or buy another one.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 10-14-2015, 07:26 PM   #3
GreenBay1921
Will a Saginaw that was in a lwb work on my swb if I get a new driveshaft?
'68 Chevy C10
'04 Infiniti G35
'01 Infiniti QX4
Old 10-14-2015, 07:29 PM   #4
EARNHARDT#3
Yes. Again I don't know about shifter linkage though. My local shop charges $70 to shorten and balance a driveshaft.
Old 10-14-2015, 07:37 PM   #5
firedemon
i don't know if mine is a Saginaw or Muncie do you have a couple pics of yours I have the stock linkage from mine your welcome to . mine is a 67 long bed l6 I converted to floor
firedemon is offline   Reply With Quote
Old 10-14-2015, 07:47 PM   #6
GreenBay1921
'68 Chevy C10
'04 Infiniti G35
'01 Infiniti QX4
Old 10-15-2015, 10:01 AM   #7
dell72
Not to hijack the thread but I have a few questions.How would a person identify the muncie from the saginaw? Is one stronger or preferred over the other? I have a 69 C-10 that is all stock with an I-6 3OTT.
dell72 is offline   Reply With Quote
