10-14-2015, 08:17 PM | #1 |
85 C10 removing oil pan
I had my abc 350 rebuilt about a month ago, ran great. I drove it to school 45 miles on the interstate at 70 MPH ran great but on the way home something came loose. Either my manifolds are rattling like a SOB or its my high volume oil pump. I've read the the inlet tube should be welded / locktite on, but I didn't install it and don't know if it was or not. I changed the oil today because it needed it, should've done it then honestly.. No metal was in it. I added the new oil and filter back in but now I'm thinking of draining it and pulling the pan to see if its my oil pump rattling so bad..
Can I remove it without with the engine in the truck? Again, its an 85 GMC C10 2WD Whats the torque rating on the pan? Thanks guys
85' GMC Sierra Classic Built 350; Weiand intake, Holley 600, Thumpr Cam Built 350 turbo with shift kit & 2500 Stall Thumpin' away |
10-14-2015, 08:42 PM | #2 |
Re: 85 C10 removing oil pan
I did it on my 69 and had to raise the motor 1/2" or so. Cross member dimensions are pretty similar from 67-87 so I'm guessing it would be the same deal.
I'm sure someone will chime in with a more definitive answer.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73 |
10-14-2015, 08:59 PM | #3 |
Abc lol I meant to say SBC up top, can't edit it now. Man that sucks.. I'm no mechanic and I wanna be able to do this but if the motor needs to be lifted I'm taking it to a shop.
10-14-2015, 09:17 PM | #4 |
It wasn't too difficult.
I had to unbolt the motor mounts and trans mount. Then lifted it at the harmonic balancer using a jack and 2x4. If you dont feel comfortable doing it then I would recommend you take it to a shop.
10-14-2015, 09:20 PM | #5 |
Also why not take it to the shop that did the work? They should have some sort of warranty I hope.
10-14-2015, 09:30 PM | #6 |
Well, the guy is out of town until November. Something with family I believe he said. He built my engine and trans. If its something I can do without too much work, I'd rather get my hands a little dirty then lug it up to his place.
10-15-2015, 04:06 PM | #7 |
You should be able to drop the oil pan without lifting the engine up , I removed mine to check the rod bearings , its the 305 but the 350 should be the same I would think .
1985 Chevrolet Custom Deluxe 4x2 , 305 v8 , 700R4 transmission |
10-15-2015, 10:16 PM | #8 |
I'm gonna get up underneath tomorrow and take a close look and decide then. Thanks guys, wanted to have some other opinions.
10-16-2015, 12:01 AM | #9 |
yeller
Oil pans, from small block to big block on 73-87's, can be removed by simply removing the pan bolts. I recommend using the fel pro one piece gasket...makes the job much easier.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
10-16-2015, 12:19 AM | #10 |
I bought a fel pro engine gasket kit before doing the build. It does indeed have a one piece gasket. Is the torque for the bolts 12 pounds? That's what I've seen online.
10-16-2015, 01:59 PM | #11 |
Before digging into the oil pan and dealing with that mess, I took my sisters stethoscope and creeped underneath while it was running. Oil pan no noise, tranny no noise, bell housing NOISE. Correct me if I'm wrong, but the cover that covers the flywheel/flex plate whatever you wanna call it and the torque converter. Took that off and it was fine! No noise. Looked at it and my flywheel was grinding it, took some paint off and it's bent. Where can I get a new one? What's the real name, if I'm getting it wrong? Dust cover/plate? I'm a happy guy right now.
10-16-2015, 11:45 PM | #12 | |
10-17-2015, 12:46 AM | #13 |
Thanks. I'll be buying a new one or going to the junkyard if this one acts up again!
10-16-2015, 05:42 PM | #14 |
Inspection cover has been the name I used.
Paul |
10-16-2015, 08:06 PM | #15 |
I'm sure it can be straightened to work good enough.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
10-16-2015, 10:01 PM | #16 |
I'm going to straighten it paint it and install it back in, if the noise comes back I'll know to check it and see if paint is missing. Thanks guys
