Old 10-17-2015, 09:10 PM   #1
Ice&burban
HVAC question
Ok, I've got a 90 Burb. I'm wondering if I need to replace the HVAC heater/ac controls. No matter what position I put the the control on (vent, heat, def, etc.) I always get heat out the dash vents. My ac has never worked (either compres or needs charged) but I'm worried about it, always cruise with widows down in summer. Also, if I put the control on cold I still get warm heat. Not as hot when it on warm, but still heat. I did purchase a new cable from LMC (it was a little long) and change it, but it's still warm heat coming out. Do you think I need to replace the entire control set up or could it be something else?
Ice&burban is offline   Reply With Quote
Old 10-18-2015, 10:45 AM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: HVAC question
Is the switch vacuum or electrical?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 10-18-2015, 09:10 PM   #3
Ice&burban
Re: HVAC question
Electric if I remember correctly. It's been a year since I had it apart.
Old 10-19-2015, 10:19 AM   #4
68Timber
68Timber's Avatar
Re: HVAC question
I've never owned a square that new so I don't know if your blend doors are cable-operated or have actuators. It sounds like you may have actuators. Either way, it's not difficult to break it down and see then put a multimeter on it. I wish I could point you directly to the problem, but that's the way I'd approach it.
John
74 Honda Z50 build
Old 10-27-2015, 07:52 PM   #5
Colt1911
Colt1911's Avatar
Re: HVAC question
Sounds like a vacume supply problem. Good luck....
....What's in the bottom of your tool box....
http://i1036.photobucket.com/albums/...od/5%20149.jpg
Colt1911 is offline   Reply With Quote
Old 10-27-2015, 08:18 PM   #6
68Timber
68Timber's Avatar
Re: HVAC question
Did you get a chance to look at it?
John
74 Honda Z50 build
Old 11-28-2015, 12:55 AM   #7
Myers horsepower
Myers horsepower's Avatar
Re: HVAC question
I had the same problem on my 1990 crewcab, it was the plastic piece on the door that the vacuum arm hooks to, you can remove the black plastic piece of the heater box behind the glove/ ashtray area to get to it, I had to make a new piece, not sure where to get a new one at.
1990 chevy Crewcab K30 454tbi/th400/np205twin stick/14bltFF,eaton posi/D60.
1972 CST K5 350/th350/12blt,eaton posi/D44
1970 K10 SWB
1970 K20 350/th350
Myers horsepower is offline   Reply With Quote
