![]() Join Date: Mar 2012
easy install??
would this be an easy install , I am assuming just get the LS engine mount kit, and a electric fuel pump ?? would I need some kind of stand alone controller???
this would go into a 72 C-10 http://www.blueprintengines.com/inde...es-psls4270ctc
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
![]() Join Date: Jan 2011
Re: easy install??
Not quite that easy. Will need a bigger than stock fuel line, a radiator for the LS engine, All the accessories for the front, Headers and exhaust to fit the LS, Then decide what you want for a trans and what you have to do to make that work with an LS. And thats just a good start.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
![]() Join Date: Apr 2005
Re: easy install??
You can buy a complete motor/transmission/wiring harness from GM for that price: Connect and Cruise....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#4 | |
meowMEOWmeowMEOW
Re: easy install??
Its hard to argue with getting the product from the horse's mouth so-to-speak. They cost a pretty penny, but I have yet to hear of anyone getting a "bad" one from the CnC packages, or even the E-Rod for the cali guys.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
