Old 10-19-2015, 11:13 PM   #1
66ChevyMax
66ChevyMax's Avatar
Brake Question
Got a brake question, I have bled the brakes starting with closest, depress pedal and open bleed valve and fluid shoots out with plenty of force.
Pedal never tightens up, brakes only work when almost to the floor. No leaks, I'm thinking master is bad? Is there something with the master I can check or am I SOL?
Thanks,
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 10-19-2015, 11:18 PM   #2
blown240
blown240's Avatar
Re: Brake Question
I was always told to start bleeding with the farthest...
Maybe that would help.
OR, is it drum brake? are the drums adjusted correctly?
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 10-19-2015, 11:20 PM   #3
66ChevyMax
66ChevyMax's Avatar
Re: Brake Question
I will try working towards the Master, new 4 wheel disc.
Craig
Old 10-19-2015, 11:28 PM   #4
blown240
blown240's Avatar
Re: Brake Question
My buddy got all new CPP discs on his 71. We had to bleed the crap out of it to get a pedal....
Old 10-20-2015, 12:48 AM   #5
Captainfab
60-66 Nut
Re: Brake Question
Start bleeding at the furthest which is the left rear, then right rear, right front, and then left front and see where your brakes are at. Also check to see that you are getting fluid at all 4 calipers. If not it is possible that the valve in the proportioning valve has slid one way or the other and needs to be centered again. POL sells a little tool that keeps the valve centered until you get the brakes bled.
Old 10-20-2015, 09:20 AM   #6
cg285
Re: Brake Question
bleeding either way works, (close first, close last). doesn't take as long if you work your way from the master cyl back.
you have a modified brake system. lots of possibilities with the installation.
cg285 is offline   Reply With Quote
Old 10-20-2015, 07:57 PM   #7
66ChevyMax
66ChevyMax's Avatar
Re: Brake Question
Define "the crap" like 3 times or 10 times
Craig
Old 10-20-2015, 08:02 PM   #8
66ChevyMax
66ChevyMax's Avatar
Re: Brake Question
Bled from back to front, used clear tube and plastic catch. No air bubbles at all seen in the clear tube. Pedal gets a tiny bit better, let it sit for a minute and back to having a live pedal only on the last 10% of travel.
It's enough to stop the truck but I'm not liking it and I'm tired of brake fluid
Any ideas or help is welcome.
Craig
Old 10-20-2015, 08:56 PM   #9
WOLFMANmike
WOLFMANmike's Avatar
Re: Brake Question
i dont know if this will be of help to you or not as it sounds like my situation too .. only that you have a full custom brake set up and i got back yard mechanic crap POS Previous Owner Syndrome thanks Chevy Mike for that wording lol ok now back to my idea on mine the PO put in a 1985 bronco II brake master and booster set up plumbed really stupid but we wont get into that anyway Chevy Mike looked at my brake peddle and saw that the biggest reason for my peddle being so close to the floor is because the PO welded that brake push rod in the wrong location on the peddle so because of that my brakes are working very close to the floor ... since yours is a full custom aftermarket jober i was thinking maybe the same issue only that your rod should be an adjustable one so look for some kinda adjustment on that ? just an idea like i said i could be wrong but it never hurts to check ... HAPPY TRUCKIN
WOLFMANmike is offline   Reply With Quote
Old 10-20-2015, 10:30 PM   #10
66ChevyMax
66ChevyMax's Avatar
Re: Brake Question
The rod is adjustable, I will start there and take some slack out.
Craig
Old 10-20-2015, 08:43 PM   #11
slowGN
slowGN's Avatar
Re: Brake Question
Did you drill a new hole on the brake pedal. When I put power on mine I had to drill a hole about 1 inch below the factory hole. That took up all the slack.
slowGN is offline   Reply With Quote
Old 10-20-2015, 10:29 PM   #12
66ChevyMax
66ChevyMax's Avatar
Re: Brake Question
I did not, it calls for one 3/4" below the factory hole but I didn't like the angle that created. May have to follow the instructions after all
Craig
Old 10-20-2015, 09:25 PM   #13
MikeB
MikeB's Avatar
Re: Brake Question
Did the brakes ever work, or is this a brand new setup?
If new, did you bench-bleed the master cylinder (or firewall-bleed it with brake lines disconnected? Are the bleed screws located on the top of each caliper?
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 10-20-2015, 10:31 PM   #14
66ChevyMax
66ChevyMax's Avatar
Re: Brake Question
Brand New Setup, CPP disc and master, I firewall-bleed it with lines disconnected. I'm not seeing any air in the lines.
Craig
Old 10-20-2015, 10:32 PM   #15
blown240
blown240's Avatar
Re: Brake Question
You need to drill the new hole and move the rod. Makes a big difference. And by a crap ton, I mean 7-8 full bleeds...
Old 10-20-2015, 11:19 PM   #16
66ChevyMax
66ChevyMax's Avatar
Re: Brake Question
Adjusted the length of the push rod and I think we are getting somewhere. I will start over tomorrow and move the hole down.
Thanks for all the help
Craig
Old 10-21-2015, 04:22 AM   #17
WOLFMANmike
Re: Brake Question
your welcome brother Happy Truckin
Old 10-21-2015, 10:38 PM   #18
66ChevyMax
66ChevyMax's Avatar
Re: Brake Question
move the hole down 3/4", extended push rod about 1/4", SUCCESS
Thanks again guys, I feel like an idiot, but I'm a idiot with BRAKES!
Craig
Old 10-22-2015, 01:59 AM   #19
WOLFMANmike
Re: Brake Question
Not a idiot brother you cant know everything. the only idiot is the guy who never asks what he needs to know about his project . and does not use the vast information this board and its people have to offer . i have learned that no question is to dumb to ask even the smallest ones that we feel we should know . are always answered to the best of everyone's ability's .. always remember that Happy Truckin
