Wich plugs for an hei distributor?
I have a71c10 that ive been driving arround town for a couple of months. The truck sat for 10 years and its got who knows how many miles on it. Its got a 350 and im going to replace the points dist with an hei dist that came out of an 83 van. right now its got " autolite 25''sparkplugs that have been on there for at least 11years. I went to autozone and they recommended everithing from iridium, platinum to copper, like 10 diifferent plugs. So i just wanna know if there is a difference between points an electric distributor sparkplugs, and what you guys would recommend, any help is greatly appreciated. Thanks
Re: Wich plugs for an hei distributor?
R45TS set at .45[forty five thousands]
![]() Join Date: Oct 2010
X's 2
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
Set the gap that wide and the engine will not start.
.045 = 45 thousandths of an inch. .45 = almost half an inch. Bill
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
Copper has a low resistance so it's perfect for a points system, the downside is they are only good for 10,000 to 20,000 miles.
Platinum has a slightly higher resistance and is perfect for an HEI system, the upside is you can get 60,000 to 100,000 miles out of them. I would go with NGK Platinum. |
I agree R45TS plugs set at 0.045" is correct for a 350 with HEI. As the last post said forty-five thousands of an inch 0.045" not 0.450". Big difference. It was just a typo in the first post on the gap numbers.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
sub'd.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor. ![]() |
]I decided to go with the ac delcos R45TS gapped at .045, put the hei distributor with new cap & rotor,
8.8 mm sparkplug wires and set the timing. And man what a difference, I had so much power compared to before that 3 days later I blew out the transmission ! Well looks like the next item on my "turning this into a daily driver" to do list is replace the th350 with a 700r4. Thanks to all for your advice. |
![]() Join Date: Feb 2015
I have been into FJ40 land cruisers now for the past 20 years but now back into a 69 chevy truck. It has a hei distributor and was hard to start when hot. I moved the dist. around making it ping and moving it back a little until it stopped pinging but it would cut out at high rpms. I removed number 1 plug and it was gapped at .030. Picked up new wires and R45TS plugs at Orileys and they said set the gap at .060. Now I am confused.
#10 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
^^ .060 is too much. As noted above in multiple posts, .045 is the correct gap for copper plugs and HEI.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
For us guys with pertronix systems (stock cap and wires) What should we be using? Stock points gap and wire set up or widen the plug gap?
![]() Join Date: Feb 2002
When I ran a PerTronix Ignitor II on my 292 L6, I gapped at HEI standard .045.
Awesome, thank you. I have a ignitor II on my 250, clifford intake and 4 barrel carb. I need to do a tune up and that info will up. Any reccomendations for coils or should a stock replacement suffice?
#15 | |
I suppose if you could find a coil by a different manufacturor that had a primary resistance value of 0.6 Ohms -- that was also OK for electronic ignition -- that would work too, but the FlameThrower II is engineered to work with the Ignitor II module right out of the box. JEGS has the Flamethrower II p/n 751-45011 for $41, more if you want chrome [$44] or epoxy-filled [$50].
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 10-29-2015 at 04:05 PM. |
#16 | ||
"I ain't nobody, dork."
Anytime you have a hotter spark ignition system you need to widen the gap on your plugs.
I run an MSD Pro-Billet HEI and a Digital 6AL box... I have my gap set at .055 as per recommendation from MSD. Gary
#17 |
Resurrecting this old thread as it's exactly the next task I am trying to work out.
So I think I'm going wit a PerTronix 1 module and a new coil and wires. From everything I have read I'll get the R45TS plug. I assume that's the AC Delco part number? My question is regarding gap. How do you know if the gap needs to be bigger or not? |
#18 |
Parts and more parts
It is a fact: The hotter the spark, the larger the gap is desired. This is how the later model vehicles are set up to get a cleaner burn of the lower grade fuels. On my 383 stroker engine, I run a Carb Shop built HEI with 8 MM wilres and Accel plugs (to get the shorter porcelein body for my headers(, the ones that I use are the same heat range as the AC R45TS plugs. I set my gap at .045 and have had no issues with the engine. I do run my timing at a higher setting than most, but I get decent mileage and good horsepower.
If you want to think a littler further outside the box. Consider setting up a MSD 6AL multi-spark unit and get a more complete burn on your fuel and ilk out every ounce of energy out of each gallon of gas.
Frank |
#19 |
Got it. Thanks. My question is a little less technical I think. How do you know if the gap needs to be bigger or not? Is there a noticeable sound difference in the engine? Like more or less pinging when set up right?
#20 |
Mr. Cheyenne
![]() ![]() Join Date: Jun 2020
So about Acdelco R44T vs R45TS, also using Ignitor II, wires and coil. Stock 350 (mild cam) in 72 C10.
Napa, Autozone, O'Riley's and Amazon all say the R45TS isn't for my 72 C10 350 but the R44T is. So, I tend to believe you guys more but gee, nothing online says to use the R45TS (everywhere says R44T). So what is up with that? Do I really go with the R45TS? So I get (I think) the 45 is a hotter plug (good for GM HEI / PerTronix Ignitor with 0.045 gap) and the the TS vs the T is tapered?? Sorry, just want to be sure I'm getting what most actually have put into their 350s and are happy with them.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 03-27-2021 at 10:38 PM. |
#21 | |
#22 |
I have a '71 GMC w/350 V8 and HEI. My mechanic says 45s are too hot for me and to stick with the 44s.
But I quit using AC-Delco plugs when they stopped making them in Michigan. I think they're made in Michoacan now. I went to Denso.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 03-28-2021 at 07:22 PM. |
#23 |
Mr. Cheyenne
stock, only non-stock is the the Ignitor II mild cam.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
#24 |
Mr. Cheyenne
I guess R45TS fit okay, this is what my brother installed. They look okay and recovered form their oily mess after I had to get my valve seals replaced (long story of brother f'n up). They appear to match the color charts for spark plugs that I have seen on the web.
Though, I can't tell it R44TS (cooler?) would be better next time.
#25 |
20' Daredevil (Ret)
Went through some of my notes and I'm not sure where I came up with the info years ago.
FWIW, I am running R44TS which is an extended tip plug. Basically stock 350 with HEI.
