Old 10-23-2015, 06:00 PM   #1
his15153
Fuel level sender
I have a 1969 Chevy C10. The gas tank was moved from the cab to under the truck bed. The truck had a bunch of cheap aftermarket gauges installed. I have purchased and am trying to install the factory gauge set. I am having an issue with the fuel gauge. It does not work with the sender that is currently in the tank. Has anyone had any luck finding a sender unit for an aftermarket tank that works with the factory gauge?
his15153 is offline   Reply With Quote
Old 10-23-2015, 06:12 PM   #2
hugger6933
Re: Fuel level sender
Sure no problem you need a 90 OHM sender several companies make them you can get them from Jeg's or Summit or Speedway. Jim
hugger6933 is offline   Reply With Quote
