10-24-2015, 01:35 PM | #1 |
wiper motor bench test
Any help would be appreciated. ?...I am bench testing my 65 wiper motor- washer. I can only get the motor to make one revolution under power.....then the motor stops.....if I manually move it to continue the revolution it will again go to the same stopping point under power. Is this correct?
10-24-2015, 01:37 PM | #2 |
Re: wiper motor bench test
I have the wiring correct according to threads here and I do have it connected to a switch to simulate normal operating conditions........
10-24-2015, 02:32 PM | #3 |
So for future reference. ?.......I relooked at my lackmof ground and realized the switch needed to be grounded as well. Problem solved. Now a new problem is the size of the holes in the existing motor mount bracket on the underside dash....the screw holes are so damn small compared to the bushing holes used to mount the motor???
WHAT gives with that???? Thats what happens when you get a truck in a box |
10-24-2015, 04:26 PM | #4 |
Moderator
Don't feel pregnant.
10-24-2015, 06:01 PM | #5 |
I figured I would upload a pic of my illusive GMC in process
http://67-72chevytrucks.com/vboard/a...1&d=1445723829 |
10-25-2015, 07:22 AM | #7 |
Thank you.....very kind words!!
