10-28-2015, 04:36 PM | #1 |
Andy
Clear Image Headers (trans crossmember)
I just ordered a set of these for my C/10 with 1 3/4" primaries. What are you guys doing about the cross member for the trans? Are you running an aftermarket cross member? Do you have any photos of how you have your exhaust routed? Thanks.
1967 Camaro SS 406|522hp/514ft lbs|M20 Muncie|3.73s|Posi 1969 CST/10 383|Aisin AR5 5 speed 1972 K5 350|Turbo 350 4x4 2005 Duramax 2500HD 4x4 |
10-30-2015, 11:48 PM | #2 |
Andy
Re: Clear Image Headers (trans crossmember)
anyone?
10-31-2015, 01:04 PM | #3 |
My truck is a big block with a turbo 400 and a gear vendors overdrive. Sanderson long tube headers and Doug Thorley electric exhaust cutouts do not leave much room for exhaust tubing. Aftermarket trans mount and 2.5 in diameter tubing with 14 inch magnaflows mounted above the trailing arms. Exhaust exits under the rear bumper after running around the stainless steel tank mounted under the bed, behind the differential. Hope that helps.
10-31-2015, 06:05 AM | #4 |
What vehicle do you have? 2wd or 4wd? What transmission do you have? Manual or automatic? What headers do you have? full length, 3/4 length, shorties? All I know is on all the trucks I've put headers on, no matter what type of truck, engine, transmission, or type of headers, I have an exhaust shop bend the pipe to go wherever it needs to go to stay no lower than the bottom of the frame...always over the crossmembers. Never heard of Clear Image headers. Are they any good? The name sure doesn't fit the product.
11-13-2015, 10:02 PM | #5 | |
Andy
Here is a description of the headers. http://www.clearimageautomotive.com/...72_headers.php
