Old 10-28-2015, 05:54 PM   #1
bvb69C10
1969 C/10 zerk fittings
Can somebody tell me how many zerk grease fittings there are on my 69 c10 front end? I don't see any on the back of the truck so I guess the only lubrication fittings are on the front? Any help would be appreciated...thanks.
bvb69C10 is offline   Reply With Quote
Old 10-28-2015, 05:57 PM   #2
Kennuck
Kennuck's Avatar
Re: 1969 C/10 zerk fittings
Near as I can recall 12 on the front end. Don't forget the driveshaft.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 10-28-2015, 07:23 PM   #3
bvb69C10
Old 10-28-2015, 07:25 PM   #4
bvb69C10
Thanks. Where on the driveshaft, u joints? Do you use the same chassis grease?
Old 10-28-2015, 07:36 PM   #5
Kennuck
Kennuck's Avatar
Yes u joints if they haven't been replaced with non greasable ones. You can use the same grease.
1970 Short Wide
Vintage Air
Old 10-28-2015, 07:43 PM   #6
Kennuck
Kennuck's Avatar
I recounted there are actually 18. 2 each upper control arm 2 each lower control arm 2 ball joints, tie rod end at knuckle, tie rod end on center link, pitman arm. so that 9 on one side plus another 9 on the other side.
1970 Short Wide
Vintage Air
Old 10-28-2015, 08:15 PM   #7
bvb69C10
Wow, that's a bunch..Thanks again. I'll hunt them all down
