Old 11-03-2015, 07:11 PM   #1
Kaptain Kadian
Kaptain Kadian's Avatar
r134 condenser
I have read a lot on this forum about changing the condenser over to a more efficient one for r134, but can't find any specific part numbers or where to buy one that would be better. Anyone know where to buy a better condenser for r134? Thanks.
I had this on the wrong message board
Kaptain Kadian is offline   Reply With Quote
Old 11-03-2015, 07:59 PM   #2
Waldoe
Re: r134 condenser
I just installed this one today. Can't tell you anymore, other than I had to make brackets, relativity easy to do. It takes up most of the space. looks to be about as big as could fit. Having hoses made tommorrow. Don't know how well it works yet.
http://www.ebay.com/itm/181701112264...%3AMEBIDX%3AIT
1970 GMC Sierra Grande Custom 2500
265/70/16, th400, 502ht
Waldoe is offline   Reply With Quote
Old 11-03-2015, 08:23 PM   #3
Kaptain Kadian
Re: r134 condenser
Thanks. Do you have any pictures of it with the brackets and mounted? You will have to keep us updated on how it cools. I plan on running a sanden style compressor and wanted to get the best cooling possible.
Old 11-03-2015, 08:45 PM   #4
Waldoe
Re: r134 condenser
I am using the a6 compressor and poa valve calibrated for 134a. completely flushed the system.The original condenser worked great, but in phoenix at stop lights, I am sure in the hot summer it would not work well. I got 42 degree air going down the hiway and idling for a short time, at 100 degrees outside. It looks like that it will be easy to seal up the edges for more air flow at idle, if this does not work out well. It will be next summer for the real test. any taller and it would hit the bottom of hood latch.
Old 11-03-2015, 08:49 PM   #5
Waldoe
Re: r134 condenser
I was also able to use the original mounting holes.
Old 11-03-2015, 09:47 PM   #6
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: r134 condenser
subscribed
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 11-03-2015, 10:21 PM   #7
Kaptain Kadian
Re: r134 condenser
How did you make the brackets? Looks really nice
Old 11-03-2015, 10:36 PM   #8
Waldoe
Re: r134 condenser
2 pieces of 1 1/4 x 1/8 strap cut to 17-18 inches long each. Used aluminum from home depot to space out 1/2 to 3/4 inches from condenser. Radiator had a small leak, so decided to replace the condenser and water pump and all belts at the same time. Probably easier with the radiator out. about $15 in parts.
Old 11-03-2015, 08:46 PM   #9
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: r134 condenser
I bought the whole kit from Classic Air group.
Here is the kit and it's all upgraded for 134A. Everything you need for a performance AC!
Original Air Group's affordable & easy to install high performance factory air-conditioning upgrade kit will help you save on horsepower, give you better fuel economy and performance, allow for a continuous duty rating of 6,000 RPM and save half the weight of the stock compressor, and function every bit as efficiently with the newer 134a refrigerant as it did with the old R12 refrigerant. It's also the easiest and most affordable way to convert your air conditioning system to the newer 134a! Kit includes rotary compressor, compressor mounting brackets, high-performance parallel-flow "Perfect Fit Series" condenser, suction, discharge & liquid hoses & lines, filter-drier, o-rings & hardware and all the tech support you need. For factory air-conditioning equipped vehicles only. Pulleys are additional, if needed.
https://originalair.com/67-72-chevro...standard-mount
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-04-2015, 05:26 PM   #10
Fitz
Re: r134 condenser
Originally Posted by Andy4639 View Post
[B][COLOR="Red"]I bought the whole kit from Classic Air group.
Is that a big enough font?
Fitz is offline   Reply With Quote
Old 11-04-2015, 05:38 PM   #11
Andy4639
Old member
Andy4639's Avatar
In other posts about this info people have asked about the 134a parallel-flow stuff. Some even said it wasn't. I just wanted it noticed in the post that it was and it was by your post!
Old 11-05-2015, 02:28 PM   #12
Kaptain Kadian
Re: r134 condenser
Any update Waldoe? I am curious to see how it is going to work. Thanks.
Old 11-05-2015, 03:21 PM   #13
RichardJ
Re: r134 condenser
I agree with Fitz.
You wouldn't offend anyone if you lost the RED TEXT and all that unnecessary crap in your Signature. Just my opinion, but I bet others would agree.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 11-05-2015, 04:53 PM   #14
Kaptain Kadian
Re: r134 condenser
Anyone know a part number for an evaporator core?
Old 11-05-2015, 07:51 PM   #15
Waldoe
Re: r134 condenser
Still working on it, as I am doing other maintenance on it. Should possibly charge the a/c fri or sat. Remember, my a/c worked great before the condenser, and it is not even hot now. I only replaced it it in hopes that it works better when the outdoor temp gets high. The condenser came charged with air, so It probably does not have any leaks. If I had to do it over again, I would probably get the black version of it. The silver shows through the grill alot. Maybe my eyes just are not use to it. I will let you know when I charge it.
Old 11-05-2015, 08:11 PM   #16
Kaptain Kadian
Re: r134 condenser
I looked for a black one and could only find it in a 16 X 26. Do you think a bigger one would fit? My bolt holes measure 16X28.
Old 11-05-2015, 08:50 PM   #17
Waldoe
Re: r134 condenser
I do not think one any bigger would fit with ease. Someone on here bought a black one from american radiator if I remember right. Looks like the same one as I have to me. any taller and it would hit the hood bracket, i guess you could lower it, but no air would pass.
Old 11-05-2015, 09:43 PM   #18
Waldoe
Re: r134 condenser
american radiator #9011239. looks like the same one, except black. Coppertone posted that awhile back.
Old 11-06-2015, 01:11 AM   #19
Kaptain Kadian
Re: r134 condenser
The condenser isn't bad at $52 but they charge $22 shipping. Shipping is getting brutal. I bought a part from a guy in California and he charged me $35 to ship it here. $40 part and $35 in shipping. Brutal
Old 11-06-2015, 02:11 AM   #20
picklito
Re: r134 condenser
I'm just curious and not critical about why you want to change the condenser? I know that's a commonly recommended "upgrade" but I am not finding it necessary. After a very careful AC rebuild and POA re-calibration to 26.5psi, my AC system is so far blowing 40 degrees at the center vent, no matter what, with the stock condenser. It's a stock 402 with stock clutch fan and radiator if that helps.
picklito is offline   Reply With Quote
Old 11-06-2015, 09:56 AM   #21
Waldoe
Re: r134 condenser
I admit that I have not had this truck in the hot summer yet, but I am familiar with 134a conversions. I guess it is possible that the original condenser would work in the hottest parts of the country, but I doubt it. If I lived where the temps did not get over 95 or so, I would have left it alone. The head pressure goes to high in the hot summer when at a stop light, which makes the air not as cold,hard on the compressor,ect. at least this has been my experience. My radiator developed a leak and it was a great time to address this potential problem, not to mention that I do residential a/c for a living, so it is not a big deal for me.
Old 11-06-2015, 12:40 PM   #22
picklito
Re: r134 condenser
My condenser was in good shape so I just tried it. I do it myself, too, which obviously makes a trial more cost effective. Since you're a real AC guy it will be valuable to hear what you think so please let is know how it comes out.
Old 11-06-2015, 08:41 PM   #23
Waldoe
Re: r134 condenser
Got it charged and it works great. The head pressures are great also. It would not be fair to say without a doubt, that it will work in the summer idling, but i think it will. It is just not hot outside. I was able to only have fittings made to connect to the existing lines, so changing back would be quick and easy. The fittings were $45. The first shop I went to wanted 100.00 for the fittings.
Old 11-07-2015, 12:30 AM   #24
Kaptain Kadian
Re: r134 condenser
Thanks for the update. My ac was never any good. I haven't had it charged in 15 years. It always leaked as well. I plan on replacing mostly everything and decided to get the most efficient things for 134. For the price, it seems like a good idea.
