Old 11-05-2015, 11:29 AM   #1
66ChevyMax
66ChevyMax's Avatar
LS3 Crate Motor Won't Start
Let me clarify it has started many times but now it won't.
This is a new crate engine purchased from Scoggin Dickey Chevrolet. It's in my 1966 C-10 and has been started many times. I have taken I on a dozen test drives and would say then engine has probably 2 to 3 hours worth of run time.
The last test drive the only thing that was changed is I hooked the alternator to the battery, gauge showed about 15 volts, drove the truck for a bout 3-4 miles and parked it in the driveway. About 15 min later I started it up again to move it into the shop, it ran for about 10 sec then sputtered and died.
When I tried to restart it didn't sound right, some knocking sounds, would sputter but not run. Pushed into the shop and called it a night.
Next day, remove power from ECM, turn motor over no noises and had oil pressure, hooked ECM back up, turns over great no noises and has fuel and oil pressure but doesn't even attempt to fire.
Any ideas or direction would be greatly appreciated.
See build thread below.
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 11-05-2015, 12:06 PM   #2
cru_zn_29
cru_zn_29's Avatar
Re: LS3 Crate Motor Won't Start
How about a squirt of fuel or starting fluid to see if need fuel or spark.
cru_zn_29 is offline   Reply With Quote
Old 11-05-2015, 12:24 PM   #3
66ChevyMax
66ChevyMax's Avatar
I have not tried that, I have a pressure gauge on the fuel rail and have 60-65lbs of pressure. It would eliminate the question though, will try.
Thanks,
Craig
Old 11-05-2015, 01:17 PM   #4
cru_zn_29
cru_zn_29's Avatar
Not if your injectors are not opening.
Old 11-05-2015, 03:39 PM   #5
66ChevyMax
66ChevyMax's Avatar
Good Point, I'm going to see if I have any codes before I proceed.
Craig
Old 11-05-2015, 01:24 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
What do you mean by "hooked the battery to the alternator"...did you not have the alt hooked up before when the vehicle ran?
Its possible you fried the injector driver on the ECM (or it just went bad). Try ground the outside of the ECM case and see if it will start.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-05-2015, 03:41 PM   #7
66ChevyMax
66ChevyMax's Avatar
No I would charge the battery, they were just short test drives.
Before I put the hood on, the ECM was just sitting in the windshield wiper area, I mounted the ECM to the firewall before the last test drive because I had the hood on and it ran great????
Craig
Old 11-05-2015, 10:42 PM   #8
66ChevyMax
66ChevyMax's Avatar
Ok found the problem, I strapped the fuse box to the inner fender for the first time since I had the hood on. I didn't put the cover on the fuse box so the strap went across the ignition relay and all the vibration wiggled it loose. Removed strap pushed ignition relay back in and she fired right up.
Craig
