Old 11-10-2015, 02:56 PM   #1
travlinman
C-30 twin saddles to single?
82 c-30 crew cab dually. Want to switch from the stock 2 tank system to a single tank. Is it as simple as it seems? Disconnect everything at the selector valve drop 1 tank an reconnect fuel line directly to the tank I want to use?
I would prefer to use the driver tank since it's more convenient to fill and less headache with switch valves sending unit etc.
Would give me more room for exhaust and an air tank on the other side.
Any help and guidance would be appreciated
94 ls swap silverado
65 Pontiac
78 c30 crew cab dually (parted and gone)
82 c30 crew cab dually ( now building )
91 r30 crew cab dually (parted and gone)
69 swb-sold
71 lab sold
all in progress......__
..........._______ |__\__
..........|__(O)______(O)] ........................
travlinman is offline   Reply With Quote
Old 11-12-2015, 01:32 AM   #2
travlinman
Re: C-30 twin saddles to single?
Not 1 person on here has done a single tank conversion?
65 Pontiac
69 swb-sold
71 lab sold
Old 11-16-2015, 01:20 AM   #3
jjmorrse
http://www.captkaoscustoms.com/blazertank.html
jjmorrse
86 C30 crewcab big dooley. 454- 400
jjmorrse is offline   Reply With Quote
Old 11-16-2015, 02:04 AM   #4
travlinman
Thanks but I don't want to do a suburban tank I just want to be able to use 1 saddle tank that I already have. Preferably the driver side but either would work. Just how do I eliminate 1 tank and keep everything working properly?
65 Pontiac
69 swb-sold
71 lab sold
Old 11-16-2015, 10:49 AM   #5
school boy
school boy's Avatar
I just done this a month ago, it wasn't hard but time consuming for me since I put in new fuel lines and was removing my tbi wiring harness. if you want easy, cap your fuel ports going to the passenger tank and remove the tank and lines. Or just connect the the fuel lines from the driver tank to the lines past the selector valve.
Are the fuel pumps in the tanks?
.....__
school boy is offline   Reply With Quote
Old 11-16-2015, 12:50 PM   #6
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
I bought my C30 with only one tank and it was setup with the selector valve zip-tied out of the way and the lines were spliced directly together from the single tank to the engine where they would otherwise connect to selector valve.
1988 Chevy R30 Dually Crew-Cab - Build thread Cummins swap + Bagged and Bodied on Semi wheels, work in progress
Ghostwhite is offline   Reply With Quote
Old 11-16-2015, 01:40 PM   #7
tucsonjwt
If it were my truck, I would hook up both tanks and make them functional. There really are not than many parts involved, and your truck will use a lot of gas, so two tanks are nice to have.
tucsonjwt is offline   Reply With Quote
Old 11-16-2015, 09:41 PM   #8
hatzie
Moderator
hatzie's Avatar
Yup...
They are really quite simple after you look at them.
All of the parts for the 2nd generation NL2 dual tank system are still available.
There's even a guy on the board that makes the whole NL2 sub-harness but I doubt you need that.
Usually it's the dash switch... Get the ON-ON 1987 TBI dash switch. It's less obnoxious to switch tanks when you don't have to hold the switch down till it's done switching. Not sure what bonehead thought a momentary switch was needed. The valve already has an off switch inside that trips as soon as the valve shuttle has completed its' travel.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
