11-10-2015, 09:19 PM | #1 |
Rear disc conversion, is it worth it?
I posted this in the 73 forum but didn't get a response and I need to make a decision in the next couple of days so I thought that I would post my question here also.
I am doing a body off restoration on my 1973 Chevy C10 and I wanted to get opinions from people who have 1st hand or even 2nd hand experience if doing a disc brake conversion on the rear makes a big difference or not in stopping power in dry or rainy conditions. I currently have disc on the front and I'm going to upgrade those with new but since I have everything apart I was wondering if it was worth the expense and time of converting the rear brakes from Drum to Disc. Thanks for your opinions in advance. Also, I was checking into brands on brakes and rotors for the front and back and I see and have heard of Centric, Stoptech (upgraded version of Centric), SSBC, Akebono & Wilwood. Your opinions on brands would also be helpful. Thanks! |
11-10-2015, 10:23 PM | #2 |
Re: Rear disc conversion, is it worth it?
I'm not sure I can give you a definitive answer, but I do like mine. I'm using Wilwoods which I sourced from Pro Performance, a vendor on this site.
The Wildwood installation was pretty straight forward. You can find photos on my build thread listed below.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
11-10-2015, 10:40 PM | #3 |
Ya, that Wilwood setup looks sweet and I think that it has the ebrake? I think it's around $500 or more isn't it?
11-13-2015, 02:07 AM | #4 | |
11-13-2015, 07:59 AM | #5 |
Like most everyone else says, spend the money for the fronts. If you're worried about your son being safe, it's not so much brakes you should be worried about, a beautiful truck, a built engine with headers and exhaust cutouts are enticing to a young'un and he WILL abuse it. I think I can safely say we were all young once and what did we do??
Tim Yesterday is history, tomorrow is a mystery, today is a gift, that's why it's called "the present". 1971 Sierra Grande LWB, 350/TH350, Factory Air Lots, of future mods planned!! |
11-10-2015, 10:32 PM | #6 |
You have a 14 bolt so parts are readally avalable, my take is the drums are adaquate.
I did the conversion on my Ho52 as parts are becoming hard to come by, I have no regrets but i have not been on super wet conditions to see if its better or worse, I also replaced the proportioning/distribution valve with one designed for 4 wheel disk applications. I would think that being as the front disks provide more stopping power that the rears should be fine. There is another opinion that the reduced surface area of the disk VS Drums will aid in heat build up on long down hill slopes but i think the disks cool better. Only draw back using a chevy caliper is no E-brake and the law books say ya gotta have one (maybe not every state??) You can ise Eldorado calipers with mechanical E-Brakes.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
11-10-2015, 10:41 PM | #7 | |
11-11-2015, 10:39 AM | #8 |
Still plays with trucks
Mid 90's Impala SS rear disc parts are 5 on 5 bolt pattern like your C10, fit well on our trucks and have an integral parking brake.
Captain Fab on the board makes mount brackets to bolt them on a truck 10-bolt or 12-bolt. A quick search will find his thread for them.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
11-11-2015, 11:30 AM | #9 |
Old member
I did the CPP brakes with e brakes.
I would spend the money on something else in my honest opinion. My truck doesn't stop any better than it did before wet are dry. I know a lot of guy's will say it's the differences in kits and that maybe true but how many people can honestly say they have bought several kits and tried them on their trucks! I sure can't. Unless you want the look I would spend the money on front big brakes. I was hoping for a noticeable difference in stopping and it's not there at all.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
11-11-2015, 12:04 PM | #10 | |
11-11-2015, 01:16 PM | #11 |
The newest car I own is a 2002 and it stops fine with rear drums.
Now if you get the "right" gear ratio, you won't even need brakes. Just let off the gas (4.11). I won't be changing my drums out on my truck. |
11-11-2015, 01:32 PM | #12 |
I always thought 80% or plus of your stopping power comes from the front brakes. I know in my 1966 Cadillac with all drums and I lost the front drum brake fluid and guess what? It would hardly stop on the rear brakes only.
So I am in the camp of do the front and don't waste your money on the rear brakes. The drums are fine. Especially on a car like a Cadillac the drums were larger in the day. It was a Cadillac. On my 1970 GMC I have all drums and they work fine. Wish I had front disc brakes but a change is not high on my list. |
11-11-2015, 02:47 PM | #13 |
Nothing to add, but in response to gkhashem;
My '69 has drums all around of course and they serve me well, even with a load of gravel down a long grade or coming downhill on a freeway off-ramp. But we don't have weather here, we hardly know what it is actually. I guess that if he was hauling a big camper or pulling a trailer (or both) in bad weather then disks in back would be an advantage or at least offer a little "peace-of-mind". The back brakes are very important when you have 3000+ lbs. in the bed.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. Last edited by WorkinLonghorn; 11-11-2015 at 02:58 PM. |
11-11-2015, 04:19 PM | #14 | |
We won't be hauling because the more that I get into this project the more I think that I am building a show truck for local shows, crazy. So, then I'm probably going to trick out the bed and it'll be hard to want to haul anything in there. It will be a daily driver though. From the opinions, it sounds like disc would be a decent upgrade and give good looks but nicer new discs in the front and new drums in the back should be just fine and stop very well. Very helpful everyone, thanks so much! |
11-11-2015, 06:00 PM | #15 |
I would do the rear disc. Just don't use the CPP junk
11-11-2015, 03:26 PM | #16 | |
I've never had any complaint about the rear drums on my truck, or the ones on my daily driver car. But if I had big open spoke wheels, I might think the price was worth it just for the looks... maybe... if I had nothing else to spend my money on.
Nick 1972 Chevrolet C10 Stepside |
11-11-2015, 03:57 PM | #17 |
Old member
My truck has the factory 4:10 gears but I have a 4L80E in it also. It will coast pretty good now when you let off the gas!
11-11-2015, 08:26 PM | #18 |
Rear disk brake conversions are mostly cosmetic for the daily driven truck in my opinion. You may notice a slight improvement in braking if all of your components are correct. I did the conversion on my truck just because they are visible through my wheels and it looks so much better than drums.
======================================== Dennis 37 ford coupe 68 short narrow 72 short wide |
11-11-2015, 08:42 PM | #19 |
Not worth it unless you're fond of spending $$$
11-11-2015, 09:42 PM | #20 |
I put on the same Wilwood kit as Z10. I've been pleased with them. To be completely honest, I bought them for cosmetic reasons to match the front. I expected to not notice any difference, but after getting the prop valve adjusted properly, I can tell a difference. Is it drastic? No. But it is noticeable. Now, were my old drums adjusted perfectly for maximum performance, probably not. It's really just a matter of what you want, and where you want to spend $ on your truck. I would definitely do it again though.
1970 SWB Build |
11-12-2015, 12:53 AM | #21 |
personally i am running the wilwood 13" big brake kit on front and rear. 6 piston calipers in front and 4 rear with internal parking brake. also swapped in a 1"bore master cylinder and have an adjustable proportioning valve to play with my bias front to rear. I have to agree in different ways with a lot of the guys. Yes the front brakes do most of the braking for a vehicle. my kit was very pricy. there are definitely cheaper options out there. will you notice a difference if you do a disc brake swap, its entirely likely you will. the best answer to whether or not to do this is what do you want them for. I have my reasons besides looks for mine. and i can vouch that it brakes a lot faster than with drums.
1972 Chevrolet swb fleet side. - SOLD 2018 Toyota Tacoma but hunting for another C10 Link to my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=607303 Instagram: https://www.instagram.com/72c10shortbox/?hl=en |
11-12-2015, 02:11 AM | #22 | |
11-13-2015, 10:00 AM | #23 |
11-14-2015, 01:27 PM | #24 |
Ya, I know...... wishful thinking. He was doing great driving until I gave him the opportunity to drive my Mercedes CL600 on the freeway, oops... Needless to say he is a young driver and didn't give enough distance crossing lanes in front of a semi-truck, we went spinning around the freeway and stopped when we hit the wall. My car was totaled but thank God we walked away just fine. I told him that's his 1 and only accident. It was just a young drivers mistake and me telling him to get over quickly before our exit was passed. Lesson learned. We have 100's of hours into this truck rebuild so I really do think he will be careful given the circumstances.
11-12-2015, 09:35 AM | #25 |
Usually the reason we can't stop in time is our fault, not the brakes. Better brakes won't make you a better driver. Don't out drive your sight, consider road conditions, visibility conditions, all those round you, and leave adequate room to react to what is in front of you. I have always been able to stop just fine in whatever I'm in or on...all drum, disc/drum, or disc/disc. I'm not in any big hurry to do rear discs knowing that front brakes do the major part of braking. I go through front brakes and never touch the rear drums. Big rigs stop with drum brakes, I figure I can. People say discs are easier to work on, and that's a good thing, because I am always dealing with frozen calipers eating up pads while the rear brakes ask for nothing. There's nothing complicated about drum brakes, they just work as they have since the beginning. I will say that going hydraulic was a big plus!
