Old 11-12-2015, 10:45 PM   #1
OlSmokey
Fuel system completely dry
Hello so i have a carbed 1972 C10, and i recently drained all of the gas from the tank, and there was no gas anywhere in the system. I put some gas in the tank and tried to crank the engine but it didn't fire up, then after a while of cranking i looked at the line from pump to carb, and there was no fuel. is there any tips to get it to crank over? thanks!
OlSmokey is offline   Reply With Quote
Old 11-13-2015, 12:15 AM   #2
frankslagoon
Re: Fuel system completely dry
you can take the line loose at the carb and blow in the tank. that should push some fuel. put the line back on the carb, then pour a " little" gas in the carb throats and fire it up. put the air cleaner back on before ya try it. sometimes the fuel pump needs a little help getten started. it pumps a lot better at 1000 rpms then 20or 30 or whatever the starter turns it.
frankslagoon is offline   Reply With Quote
Old 11-13-2015, 12:22 AM   #3
LEEVON
Moderator
LEEVON's Avatar
Had this problem many times, I like to disconnect the fuel line at the carb, blow back through with an air gun. Sometimes there is debris in the line or at the tank pickup, other times it just needs a prime.
LEEVON is offline   Reply With Quote
Old 11-13-2015, 07:34 AM   #4
kenn
Hello I have a question if you don't mind, is it Ok to blow air past the fuel pump as you are suggesting or am I missing something?
kenn is offline   Reply With Quote
Old 11-13-2015, 09:36 AM   #5
midniteblues
midniteblues's Avatar
You could but I wouldn't suggest it.
If the pump diaphragm is weak it could ruin it.
I usually disconnect the infeed line at the pump and blow air into it.just be ready gas will/should flow as soon as you stop the air.
Or disconnect the f p in feed and blow into the filler neck.be sure too catch the fuel under the open line
Reconnect
Then pour a lil gas into carb and crank it over that should do it.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 11-13-2015, 12:08 PM   #6
2manybowties
LEEVON, if you dont mind me asking I have replave the fuel pump on a 71 also and it acts like I am getting air in the system. The old pump and the new pump will not fill the in-line filter up. When I disconnected the fuel line to blow it out alot of air spewed from the line. Any ideas where the air could be coming from?
2manybowties is offline   Reply With Quote
Old 11-13-2015, 07:13 PM   #7
Clavo106
X2 .. mostly this one..
Clavo106 is offline   Reply With Quote
Old 11-13-2015, 01:54 PM   #8
OlSmokey
Awesome i just tried your suggestions and it worked! the truck started and idled! one step closer to finishing my shortbed conversion!!
Old 11-13-2015, 05:23 PM   #9
drewbert41
drewbert41's Avatar
Which one exactly? I just drained all the fuel out of my 68 when I installed a new hardline from pump to carb. Have not put gas back in yet.
drewbert41 is offline   Reply With Quote
Old 11-13-2015, 07:35 PM   #10
Redline novdog
Redline novdog's Avatar
I usually pull the air cleaner and fill the float bowl through the air horn (tube) by the choke plate.Yes put the air cleaner back on if you value you eye brows,just in case
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
