11-13-2015, 02:41 PM | #1 |
Starter Issues, 79 c10
I have been having an issue with my starter bogging down, like really sluggish to start, i replaced the ignition switch, have a new 1000 cranking amp battery, brand new starter, and ive checked everything, i cant figure this out, has anyone else out there run into an issue like this?
11-13-2015, 02:42 PM | #2 |
Re: Starter Issues, 79 c10
Hows that positive battery cable and ignition switch wire look?
11-13-2015, 02:43 PM | #3 |
oh forgot, i replaced both positive and negative terminal wires, the ignition switch wire just needed a new end conector adn thats about it but still haveing the issue
11-13-2015, 02:44 PM | #4 |
hows your ground? anything past that bad starter? flywheel teeth missing?
11-13-2015, 02:46 PM | #5 |
i was going to check the grounds today might not be making good contact i suppose. no flywheel teeth missing, everything looks good.
11-13-2015, 02:53 PM | #6 |
check what voltage you are actually getting at the starter before you do anything else time to whip that multimeter out!
11-13-2015, 02:55 PM | #7 |
haha alright ill check that out, i guess i need to find my multimeter...
11-13-2015, 02:59 PM | #8 |
Also welcome to the forums!
11-13-2015, 03:06 PM | #9 |
Is it a cold start problem or is it a hot start problem.
11-13-2015, 03:57 PM | #10 |
11-13-2015, 04:16 PM | #11 |
There has never been a case of a ground being too clean and tight. They are a free place to check.
jjmorrse 86 C30 crewcab big dooley. 454- 400 |
11-14-2015, 11:10 AM | #12 |
Thanks , I got it figured out, the engine to cab ground strap was severed in half, idk how it was starting at all considering the engine is on rubber mounts, but i got a new ground strap and attached it engine to frame and the thing fires right up no issues! thanks guys!
