11-14-2015, 06:40 PM | #1 |
Door panel arm rests
I just purchased a set of door arm rests for my 70 C10 from classic industries but they do not sell the hardware. Does anyone know where I can get some or the correct size and maybe I can get them at a local hardware store? Thank you.
11-14-2015, 06:59 PM | #2 |
Re: Door panel arm rests
Yes
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
11-14-2015, 06:59 PM | #3 |
JK - The answer is likely DLTruck1973
Incidentally, they're an inch long to top of head. Wish I could give you a thread number. At some point I'd like to get the gauges. If you need it I'll take a photo. Just two round head screws per side.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-14-2015 at 07:18 PM. |
11-14-2015, 07:16 PM | #4 |
I just ordered the plastic square pieces that mount in the door for the screws from classic parts Inc. $.49 each. I think they might be same thing used to mount license plates.
11-14-2015, 07:24 PM | #5 |
You can buy the originals I bet, probably from the same location I provided. Not sure what they're called, but it's basically a steel nut (can't provide proper description) with metal tapered flare that punches out through the sheet metal facing cab. Look real easy to remove. Might be a small challenge to get in.
11-14-2015, 07:27 PM | #6 |
You can buy the originals I bet, probably from the same location I provided. Not sure what they're called, but it's basically a steel nut with metal tapered flares to hold the anchor in place. They look real easy to remove. Might be a small challenge to get in.
11-15-2015, 07:14 PM | #7 |
The metal nuts are called cage nuts. They are available from some of the vendors here. I found mine at Fastenal. They are 1/4-20 cage nuts.
https://www.fastenal.com/products/ca...0+cage+nuts&r= ~|categoryl1:"600000 Fasteners"|~ ~|categoryl2:"600072 Nuts"|~ ~|categoryl3:"600074 Cage Nuts"|~
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
