Old 11-17-2015, 12:41 PM   #1
Vandals909
A-arms on stock front member
What are the good options for a-arms on a stock front member? Would like to run 20's front and rear and be as low as an ECE 4/6 drop. Of course want it to handle better also.
I like the ride tech coil over kit just so much more $$$ then I want to spend at the moment
Vandals909 is offline   Reply With Quote
Old 11-17-2015, 02:43 PM   #2
bbbc10
Diggin The SquareLife
Re: A-arms on stock front member
Arms are gonna be around 1100 for pb fab that uses coil spring, cpp also has some an djm has some arms but I would stay away from them
bbbc10 is offline   Reply With Quote
Old 11-17-2015, 06:42 PM   #3
Vandals909
Why is one preferred over the other? Anyone speak from experience ?
Old 11-17-2015, 07:50 PM   #4
BossHogg69
motor exploder
BossHogg69's Avatar
If you're doing a 4/6 drop and stock crossmember, there is no real reason you need aftermarket arms unless you just want the look. You'll be better off focusing on replacing the balljoints, tie rods, bushings, getting a sway bar and some nice shocks than the 'bling' of aftermarket control arms. And yes, I do have CPP tubular arms (they are nice), and Hotchkis springs, along with double adjustable CA Chassisworks shocks. The arms are nice, but they aren't a 'must' by any means for a good handling, street driven truck.
I'm running 19's front & rear with a 5/7.5 drop if that matters.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 11-17-2015, 07:59 PM   #5
SCOTI
SCOTI's Avatar
Some are preferred over others because of improved geometry, materials, & benefits vs just being a tubular arm based on OE geometry.
DJM arms are a copy of OE w/a drop pocket for lowering. They make the already compromised scrubline on a lowered C10 worse. I would avoid them.
CPP makes tubular arms that improve geometry & provide better ground clearance as the bushings are no larger than the barrel they fit in. I'm not sure what the bushing material is as the description lists it as "self lubricating, non-squeak, patented plastic". Stock or aftermarket sway bars are compatible. They offer coil specific or bag specific options & they're about $850 or so for uppers/lowers.
Porterbuilt arms improve geometry & they have choices such as altering the wheel base 1" forward and/or narrowing track width. They can be used w/coils or bags (coils require a bolt-on adapter that's extra). The PB arms also require a spec'd sway bar vs any C10 aftermarket bar. They utilize Delrin bushings & are greaseable for maintenance which I like (I don't beleive any claim of squeak free hard plastic/urethane bushings). last I saw PB's were going for around $1,100 but vendors runs sales on them so they can be found for varying prices.
There's the Ride Tech units that work w/bags or the Coil-Over spec'd arms. Which one's you choose decide what supporting gear you'll need & the associated costs.
Don't forget about Hotchkis either..... I really like their products but if cost is a factor.....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-17-2015, 08:10 PM   #6
72 k10
scoti what do you mean by scrub line ? the seam under the doors?
72 k10 is offline   Reply With Quote
Old 11-17-2015, 08:19 PM   #7
SCOTI
SCOTI's Avatar
Scrubline is anything that can hit the ground below the wheel lip. Imagine a string pulled tightly from the front left to front right @ the outer edge of the wheel. That would be considered the scrubline. Anything below that imaginary line can contact the ground & cause damage and/or loss of control of the vehicle.
It is always advised not to allow anything to hang below that line. The rear end is the same thing. Anything below the lips of the wheels is possible trouble if it hits the ground (blow-out, object in the roadway, etc...).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-17-2015, 11:47 PM   #8
Vandals909
Thanks for all of the responses.
The idea of centering the wheel in the wheel well sounds like a great idea. Also thinkin the better geometry offered would help reduce the amount of shims currently on the arm to get it aligned.
Is porterbuilt the only one that centers the wheel?
Old 11-18-2015, 12:46 PM   #9
Vandals909
Thanks everyone.
What spindle and drop spring works best with the porterbuilt narrow and forward arms on a stock member if I want to run 20's on the front on my 71
Old 11-18-2015, 12:53 PM   #10
RodsGreen10
RodsGreen10's Avatar
That would be more of a brand preference. Cause they will bolt up just like stock. I like WC and CPP. But that's just me. PB carries CPP so you could do a one stop shop with PB.
RodsGreen10 is offline   Reply With Quote
Old 11-18-2015, 06:33 PM   #11
Vandals909
Here is some good info from porterbuilt. I asked if I got arms and decided later when money permits will running a drop member be an issue.
"If your plan is to run a Dropmember in the future you will need to stay with the standard or 1" narrowed control arms. We move the wheel 1" forward with our cross member so the forward arm will move the wheel to far forward. "
