Old 11-21-2015, 10:34 AM   #1
clemsonteg
How many miles are too many?
How many miles would you consider as too many for a donor motor/trans? What should be replaced before completing a swap with a 100k+ mile motor?
clemsonteg is offline   Reply With Quote
Old 11-21-2015, 02:17 PM   #2
Cobalt964ruf
Cobalt964ruf's Avatar
Re: How many miles are too many?
I had a personal truck with a stock 6.0 ly6 that had 340k on it. ran like a top still. so I would say check its maintenance logs and see how it runs, any blowby? oil pressure after warmup? color of oil, trans fluid smell burnt? so on...
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's
1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's
Cobalt964ruf is offline   Reply With Quote
Old 11-21-2015, 03:54 PM   #3
Clyde65
Clyde65's Avatar
My BIL, got rid of his 2004 Silverado at 360k because the front diff needed replaced. still ran great though!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-21-2015, 06:51 PM   #4
Nochance
We have a fleet customer with 680K on a 6.0 ly6 that is still going strong. Now on the other end of the scale I put a 4.8L in a 2014 Express van last month with 12K miles on it. The dealer said no warranty due to customer never changed the oil. It was a ride share commuter van that is giving to them by their company the sad part is there maintenance is paid for too. I see LS motors with 200-300K miles everyday it all comes down to the maintenance.
For my personal truck I bought a 60K LY6 off ebay that I'm replacing all the gaskets other then the head gaskets. It will be getting a new water pump and thermostat too before its installed next month.
Nochance is offline   Reply With Quote
Old 11-21-2015, 08:06 PM   #5
hugger6933
I am seeing more 320 K plus trucks in the sale that will have motors ending up in sales racks.I have also seen a railroad truck in the ride and drive portion of my salvage sale that still ran great with 556K on it.I would feel very comfortable with selling a motor going in a hotrod with 180K on it as long as I heard it I have several that I heard run and even some the customer could do the same.
hugger6933 is offline   Reply With Quote
Old 11-21-2015, 08:19 PM   #6
Tilt
My donor had 130K, I replaced the water pump, oil pump, The little oil barbell thingy, timing chain, all gaskets, front and rear seals. I was swapping the heads and cam, so I figured I might as well change it all while it was apart.
'83 Silverado Step Side
'85 GMC short bed.
'86 Chevy Step Side Custom Deluxe
LQ9/4L80 swap (SOLD)
Tilt is offline   Reply With Quote
Old 11-23-2015, 01:08 AM   #7
clemsonteg
Thanks for the advice so far. How difficult is it to replace the oil pump? I'll have to swap the oil on to an f-body pan for extra ground clearance
Old 11-23-2015, 10:06 AM   #8
Rich84
Rich84's Avatar
I have a 2004 GMC van with a LQ4. It just went over 370,000 miles this week. It tows and hauls drywall..At about 305,000 it burnt a valve. I removed the heads, replaced the valve, re-seated the others, put it back together and shes still running. I did have to replace the transmission though (3 water pumps, 2 starters, 2 alternators too).
Rich84 is offline   Reply With Quote
Old 11-23-2015, 12:31 PM   #9
slotard
Yeah, the 4L60E isn't known for it's longevity. There's some chance I'll end up with one but if I do and I kill it, I'm swapping for a 4L80E or something else.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 11-23-2015, 09:25 PM   #10
Dustytrix
Changing the oil pump is not bad, 4 bolts and use a feeler gauge to set the spacing. I think its a .20 feeler blade but not sure at the moment, might as well change the timing chain too. You will be looking at it.
Dustytrix is offline   Reply With Quote
Old 11-28-2015, 12:10 AM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
News to me, but they all run around the same pressure, so it wouldn't be the biggest surprise.
You can mix and match (gear, pump, rack n pinion if you have it) between them all if you have the right fittings. I've used the latemodel pump on old steering gears, new racks, and mid-year metric gears. Hydroboost's can also be interchanged similarly, with a few limitations.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-02-2015, 05:05 PM   #12
Wasted Income
Boosted Member
Wasted Income's Avatar
You guys running 300k+ junkyard stuff are my heros.
I used to think I was cool running 160k mile junkyard engines for my turbo setups. Never had a problem that wasn't self inflicted with any of those engines.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 12-03-2015, 01:06 AM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
All the mileage helps loosen up the ring gaps on the oil ring, which is actually how most of the FI setups crack ring lands on these. The junkyard motors are more suited for a turbo than a fresh build! I'm sure you've seen, but those guys on theturboforums beat these like race mares.
Old 12-07-2015, 04:15 PM   #14
Pillow
Pillow's Avatar
Agreed. If it has good oil pressure and is clean under the valve covers you are probably fine.
I used a 2005 LM7 core that was an all Mobil1 engine with about 150K on it. I ended up replacing gaskets and stuff for the cam swap, but really I did not have to touch anything. Later I went back and replaced the rod bearings, main bearings, and cylinder rings - but that was a waste of time as they were all in fine shape. Even the timing chain was in spec.
I sold our old Escalade with 180K to a friend and he has 250K on her now without problem. Only issue was the 4L60E, replaced at 140K.
The newer 6L65E (?) is a much better transmission if you can swing it.
So yeah. Just run it if she looks clean on the inside.
'71 C-10 with 5.3 LS2 cam & NWC T5 - Patina King!
'83 Jeep Cherokee w 5.3 LS9 cam & SM465 NP208 swap in progress
'92 Volvo 960 wagon w 5.3 LS7 cam & WC T5 swap in progress
'79 Porsche 911 SC
'48 Spartan Mansion 30' travel trailer
'10 Porsche Cayenne S - Daily
Pillow is offline   Reply With Quote
