11-23-2015, 03:16 AM | #1 |
How to identify the Rear End?
How do you identify a Dana 60 Rear End? I have a 1970 GMC C20 long bed with leaf springs in the rear. It has a 10 Bolt rear end. It is a Full Floater with 12" Drums. The Drums just SLIDE OFF, the Axles do not need to be removed to take off the Drums. It has 7 bolts attaching the Backing Plate to the Axle Housing. It is 8 Lug with 1/2" x20 Wheel Studs. Looking at the diff cover, on the passenger side, it has a code written upside-down C-30255, and below that it has the number 60. Is this a Dana 60 Rear End?
11-23-2015, 06:50 AM | #2 |
Re: How to identify the Rear End?
Here's a thread with pictures.
I have the same Dana 60 in my 1972 http://67-72chevytrucks.com/vboard/s...d.php?t=399360 J.
1972 Custom Deluxe Highlander C20 1971 Javelin SST New Project 1971 Demon 340 1969 SS El Camino 1968 SS RS 396 Camaro 1967 Barracuda Formula S 1965 140/4sp Corvair Monza Convertible Sorry, but I don't do Fords. |
11-23-2015, 08:54 AM | #3 |
That thread is mostly about front axles, but same center section. The last picture does show a rear. funny how GM corporate rears got named by number of bolts on differential cover (10-bolt/12-bolt) when that doesn't say squat. Just GM alone used four different rears that I can think of that had 10 bolts for the differential cover. And the Dana rears were found in GM, Ford, Dodge, IH trucks, Mopar cars, Jeeps, on and on
11-23-2015, 07:47 PM | #4 |
If it's peculiarly shaped it's Kim Kardashian's, if it's perfect it's Carla Gugino's? That's all I can offer.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
