Baer 14" bbk help
So I installed the pro-performance 14" bbk on my 1972 c10 around the beginning of the summer. Let me start by saying all the guys at pro-performance have been great and very helpful. But none of us can figure out the problem I am having.
So here we go. After installing the kit front and rear it became clear there was a problem. Once the brakes heat up the truck starts to make a notable grinding/ humming noise from the front end. This happens both left turning and right turning. The noise go's away when I pres on the brakes. We have replaced the steering box, controls arms, shocks, springs, ex... The noise is still there. We removed the kit several times to check if there was any uneven ware, no such issue was discovered. We changed brake pads , nope that didn't do it. We removed the inner wheel wels just to confirm, nope. So what could this noise be. As you can see this has been burning a hole in my pocket, pro-performance's pocket and my mechanic's pocket we have way over 3 weeks in trying to figure this out. A call was also made to Baer but no suggestions helped. Let me allso add, we checked drive shaft play and rear end as well all is good. HELP please. |
Old member
Just a couple of idea's off the top.
Did you changes bearings and all when you went to the new spindles for the bigger brakes. How did you tighten them down. Did you back off the nut before you installed the cotter key? Your wheels are not scrubbing the caliper is it. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#3 | |
Re: Baer 14" bbk help
#4 | |
Old member
![]() Quote:
That is how I do it. I assume you know the mechanic and he does good work. Didn't cut no corners by putting the old stuff back in the new hubs. old bearing on new surface could cause un even wear and start grinding once it heats up. Have you tried jack the front up and spinning the wheels and see if you can hear it? ![]()
#5 | |
#6 | |
Old member
![]() Quote:
Ok, drive it til you start hearing the noise then get it on stands and see if you can find it. Did you do anything else to the front end besides the brakes? ![]()
Have the jack in the driveway and go for a ride till it starts making the noise, bring it home or to the shop, jack the thing up and try turning the wheels by hand and see if you notice or hear any dragging to try and isolate what wheel or both front ect..
My first thought was wheel bearings too but if they were properly greased and preloaded then backed off about 1/8 turn then they should be fine. Maybe a distribution block or master cyl not releasing properly?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Old member
Did you take the dust covers off when you replaced the brakes.
For some reason I think I remember somebody posting about the dust covers scrubbing when they did the new spindles and brake upgrades. Don't ask where I herd this because I've been think about it since last night. I can't remember it may have been on face book! ![]()
#9 | |
Any chance exhaust is near brake lines and you're heating up fluid causing brakes to drag. This will cause the noise and will go away when brakes applied
