Old 11-25-2015, 03:06 PM   #1
Luke M
Luke M's Avatar
Smile Looking for lower control arms.
I've been on the hunt for factory style 73-87 lower control arms for a C10 and couldn't find them anywhere? I tried Rock Auto but they don't list any, called to various local auto part stores with no luck and couldn't find anything on Summit or Jegs. Does anyone know where I can find lower control arms with bushings and ball joints?
Thank you
Luke M is offline   Reply With Quote
Old 11-25-2015, 03:27 PM   #2
riz
Re: Looking for lower control arms.
I've been looking too....... curious to see what others say.
RIZ
riz is offline   Reply With Quote
Old 11-25-2015, 07:01 PM   #3
bbbc10
Diggin The SquareLife
I seen them on good old ebay
bbbc10 is offline   Reply With Quote
Old 11-26-2015, 02:19 AM   #4
mcmlxix
Collector of Projects
mcmlxix's Avatar
Unless your local dealer can locate some NOS pieces on a shelf somewhere, you looking to the junk yard... or upgrade to tubular...
http://www.classicperform.com/Store/...TCA-LKB481.htm
Rich
1972 K5 Blazer CST Click HERE
Old 11-26-2015, 02:40 AM   #5
1774btcrew
1774btcrew's Avatar
I would go with nice used and then you can go with whatever brand ball joints you prefer. I know here it is easy and reasonable to get items powder coated. The benefit of that is that the finish will last longer than on any of the aftermarket control arms.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 11-26-2015, 10:48 AM   #6
RootBeerFXS
RootBeerFXS's Avatar
Search Moog Problem Solver control arms....
Here are the part numbers
RK621269 (Left upper)
RK621268 (right upper)
RK621645 (left lower)
RK621646 (right lower)
All come with new ball joints, cross shafts and bushings. All you need is the bump stops.
Find them here..
http://www.fmmotorparts.com
The lowers are pricey, uppers not too bad. LMC also sells a complete arm for about 160.00 I think but don't know what brand they use.
RootBeerFXS is offline   Reply With Quote
Old 11-26-2015, 11:03 AM   #7
Luke M
Luke M's Avatar
Find them here..
Thanks, I was able to find RK621269 (Left upper), RK621268 (right upper) through Summit Racing. I still cannot find RK621645 (left lower), RK621646 (right lower) anywhere. I called Federal Mogul yesterday and the part numbers for the lowers are discontinued and there are no part numbers offered as replacements.
Old 11-26-2015, 11:09 AM   #8
RootBeerFXS
I ordered some last week from my local store. I will give them a shout Monday and post my findings. I sure hope that's not the case.
This truck has fought back with everything I try to do to it. Including 1 broken finger on each hand in separate instances. I brought it down off the lift yesterday and heard a loud pop. Leaf spring snapped a leaf. Sheesh.
Did you look at LMC?
Old 11-26-2015, 04:47 PM   #9
68c10owner
68c10owner's Avatar
Thought I saw OEM`s in the Brothers catalog. They are not loaded though.
Anthony
68c10owner is offline   Reply With Quote
Old 12-26-2015, 11:58 AM   #10
ChevyC102007
ChevyC102007's Avatar
Im having the same problem too, only place I can find a set of "loaded" lower arms for my 80 C-10 are from LMC. Just my .02
"When you were born, you cried and the world rejoiced.
Live your life so that when you die, the world cries and you rejoice."
[Cherokee saying]
2001 Dodge Ram Sport 1500 4x4. (old ride)
1987 GMC V1500 Sierra Classic ("new" ride)
ChevyC102007 is offline   Reply With Quote
Old 12-29-2015, 01:42 PM   #11
barry1982
I just replaced mine on the 82' I'm restoring. Originals had holes rusted through the center. Got lucky and found a 89 Suburban that was rear ended.
Lower control arms were in mint condition. Sandblasted, painted flat black, and installed new Moog ball joints. Good to go.... with minimal cost.
barry1982 is offline   Reply With Quote
Old 12-29-2015, 02:03 PM   #12
Malo83
Cruzzzn' Vet
Malo83's Avatar
The Truck Shop has built up arms, cross shafts, bushings and ball joints, page 117 in their catalog.
http://issuu.com/truckandcarshop/docs/ts_73-87_web_cat
Malo83 is offline   Reply With Quote
