11-29-2015, 12:22 AM | #1 |
Modular front disk set up interchanges?
Im doing the 4 wheels disk on this 67 truck and already have the Wilwood in back. The front already had a setup off a 72 so I installed the disks and calipers to the updated CPP drop spindles CP4S-2 that allowed the factory 67 steering linkage.
What I want to do is find something 5 lug from like a Camaro or something that has modular hubs and disks that will work with the CPP spindles and factory replacement Wilwood calipers. I want to do drilled and slotted rotors to match the rear. Wilwood only sells the modulars in a big brake kit and is way expensive. I plan on running the chrome 15" corvette rally wheels I already have. Does anyone know what will work and have the same lug pattern that will still use the factory replacement calipers from Wilwood? Any input is greatly appreciated.
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
11-29-2015, 01:19 AM | #2 |
Re: Modular front disk set up interchanges?
check EBC for the hell of it too
'68 C10 SWB '85 K30 Blazer |
12-02-2015, 09:03 PM | #3 |
Didnt see anything in EBC...
This is frustrating... There HAS to be a modular kit that uses factory replacement calipers and factory diameter rotors somewhere. I Just need the Hubs is all I need as Im sure I could find drilled and slotted rotors and would be able to use Wilwood factory replacement 2 or 4 piston calipers...
12-02-2015, 09:39 PM | #4 |
Old member
Want the older big Impala SS hubs work. They are the same as a 5 lug Chevy truck.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
12-02-2015, 09:45 PM | #5 | |
Thanks for the reply option
