Old 11-30-2015, 02:14 PM   #1
americanmusc1e
americanmusc1e's Avatar
Help. I have a lug problem
6 lugs in the rear and 5 lugs in the front
My 70 C10 was a 6-lug truck from the factory. I converted it to front disks several years ago when I wasn't aware that 6-lug disk brake kits existed. I drove for years with 6-lug wheels on the back and 5-lug wheels on the front and two spare tires in the bed. Now I would like to remedy that without spending a lot
The front of my truck has McGautys factory height conversion spindles. (they use the 67-70 ball joints and accept 71-72 rotors) and 72 crossdrilled rotors 5x5"
The rear is a '69 (manufactured in 10-68) 6-lug 12-bolt. that I salvaged from another truck. It didn't have any brake hardware on it so I grabbed a nice set of 11x2.75" drums off a scrap 4x4 squarebody 12-bolt axle.
AS I see it, I have three options.
1. replace the rear axles with aftermarket 5-lug because I'm pretty sure the pre-69 axles are a different length. I'd have to replace the drums as well, and I'm not sure they made the big drums in 5-lug.
2. convert the front back to 6-lug. I'm guessing I'd need a a set of factory 67-70 spindles which I don't think I have anymore. And then I'd need a 6-lug conversion kit.
3. Leave the different lugs front and back and hopefully find a dual-drilled spare. I haven't turned up any results for a wheel drilled 5x5 and 6x5.5.
Am I missing any ways to do this? I'm getting ready to buy new wheels
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 11-30-2015, 02:39 PM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: Help. I have a lug problem
I bought 6-lug rotors for the '71 f.e. I put on my '68. I was running 6-lug original vintage centerlines plus I wanted to retain the stock appearance.
I'm going to move you to the suspension forum where they deal with this stuff a lot more.
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 11-30-2015, 03:21 PM   #3
Renzo
If you want to stay 6 lug all u would need is a set of 6 lug rotors for the front.
If you want to go 5 lug like a lot of people do you would need to change to 5 lug axles in rear and new drums.
Renzo is offline   Reply With Quote
Old 11-30-2015, 04:22 PM   #4
michael bustamante
michael bustamante's Avatar
get the 6 lug rotors from mcgaughys, they fit that spindle no problem
1967custom
michael bustamante is offline   Reply With Quote
Old 11-30-2015, 04:32 PM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Cheapest/easiest is getting aftermarket 6 lug rotors, which would drop on your spindles and keeps all your brake stuff as you have it now.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 11-30-2015, 06:58 PM   #6
SCOTI
SCOTI's Avatar
Depends on your long-term plan.
Do you want the 6-lug pattern or are you possibly considering 5-lug wheels? Choose your path based on that decision. Aftermarket 6-lug rotors or aftermarket 5-lug axles & HD 5-lug drums (HD 5-lug drums were available for 73-87's).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-01-2015, 05:42 AM   #7
andrewmp6
Depends how you want the truck in the long run,If your happy with stock rims change the front to 6 lug,If you want aftermarket rims i would change the back to 5 lug have more options on wheels.
Old 12-01-2015, 05:54 PM   #8
americanmusc1e
Wow! you guys are awesome! It looks like I'll be swapping to 6-lug discs in the front.
I now have to decide the best wheel and tire combo for my fairly limited budget. I have an old set of 15x8 outlaw IIs that have been on the truck forever, but I really wanted to reduce the sidewall a bit to increase the performance.
What is considered the ideal wheel size for handling? I'm aware that reducing sidewall profile reduces sidewall flex and heavier wheel/tire combos increase unsprung and rotational weight. But what's the best balance for a street truck? I know that's a very open ended question, and I doubt the truck will ever see an autocross track with it's SM465 dump truck transmission. I just want something a little better than stock.
-- Josh
Old 12-01-2015, 08:33 PM   #9
BigMike
BigMike's Avatar
Another thing to consider is wheel choices. The 5x5 wheel selection is far greater than the 6 lug choices. It's a contributing factor as to why so many people convert to the 5 lug to begin with. Just some food for thought.
BigMike is offline   Reply With Quote
