Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 12-01-2015, 11:55 PM   #1
chastain90
chastain90's Avatar
Single Wall Top Hardware questions
I have yet to see a hard top installed in person and my blazer had the top off and parts scattered when I got it. I am wondering if I need to have weatherstrip between the bed rail and top and if there is any other brackets I need? I do not have my visors and I think I have to put the bolts thru the visor brackets. Thanks for any help
chastain90 is offline   Reply With Quote
Old 12-02-2015, 07:41 AM   #2
dirish
dirish's Avatar
Re: Single Wall Top Hardware questions
Take a picture of the parts you have. Maybe number them.
We can help you figure out what you need.
dirish is offline   Reply With Quote
Old 12-02-2015, 07:58 AM   #3
jjzepplin
jjzepplin's Avatar
Subbed for this info. I just got a single wall and wonder if my double wall brackets are the same.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 12-02-2015, 08:53 AM   #4
1rippen6
Second picture is what you need plus the sun visors. There is also rubber stoppers and hatch catches that bolt on with the back brackets. I can probably get you some pictures tonight if I get home in time.
http://67-72chevytrucks.com/vboard/s...d.php?t=636001
1rippen6 is offline   Reply With Quote
Old 12-03-2015, 01:22 AM   #5
chastain90
chastain90's Avatar
Ok I have some of the brackets in the middle of that second pic. I just have a tub of parts and don't know where anything goes. Is there weatherstrip that goes between top and bed?
Old 12-03-2015, 01:57 AM   #6
Blazerowner
Blazerowner's Avatar
The two small L shaped brackets go on the windshield header between the visors and bolt to the top. The larger brackets go in the back two corners of the top and hold the hatch catches and bump stops while also bolting to the bed. Yes there is rubber between the top and the bed. Check out LMC truck and their catalog has the blazer parts in a schematic layout to get an idea where things go. The top parts are a little difficult to come by so take a picture and we can tell you what's missing. You also need chrome strips that hold the top to the length of the bed. By the way Wes on here had reproduced the bump stops which are pretty much impossible to find in good shape. Look on the blazer parts board for his post. He may still have more, I bought three sets myself.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 12-03-2015, 01:59 AM   #7
Blazerowner
One more thing is yes the visors do bolt to the top. They are blazer specific and truck visors are completely different.
Kirk
Old 12-03-2015, 09:54 AM   #8
jjzepplin
jjzepplin's Avatar
What do the chrome strips look like?
Old 12-03-2015, 12:52 PM   #9
dirish
dirish's Avatar
There was a set on ebay.
Old 12-03-2015, 12:03 PM   #10
Blazerowner
Just flat strips that are about three feet long. They lay flat on top of the lip To sandwich the top to the bed.
Kirk
Old 12-03-2015, 11:53 PM   #11
chastain90
chastain90's Avatar
Would a fabricated piece of metal work as a hold down strip? I know I do not have those.
Thanks, it will be a little while before I can get it all together but thanks for the help so far.
Old 12-04-2015, 12:49 PM   #12
Blazerowner
That would work. Its better to have the strip so it spreads the tension from the bolt and doesn't crack the top.
Kirk
