12-02-2015, 05:22 PM | #1 |
Source for Steering Column Half Moon connector
HELP! Anyone know where I can find a replacement connector for the turn signal switch that plugs in under the dash/column and is shaped like a half moon or circle. 8 Pins I think have to look again!!! Or maybe a place to get the pins for the harness. Any help appreciated. Maybe someone removed their stock harness and would be willing to sell me the connector?
thanks Craig
49 Chevy Panel 235 cu in 72 Chevy Pickup 350 cu in (Friends Truck- Why did I volunteer) Thanks to all the forum gurus for their help past and present. |
12-02-2015, 10:36 PM | #2 |
Re: Source for Steering Column Half Moon connector
Go into the venders section and give one of them a call and see if its avalable.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
12-02-2015, 11:03 PM | #3 |
I guess I forgot to mention that I have searched all over the internet for one. I've searched the truck sites as well as a dozen connector suppliers and everything I could think of including Ebay. I was going to post a WTB ad in the forum classifieds but my privileges aren't good enough or something. I've asked the moderator for an assist on that issue but until then I need any recommendations I can get so thanks . What gets me is that one or more of the vendors sell an adapter that has the half moon on one end and a straight connector on the other so somewhere they get the connector to make the adapter. If I only knew where!!!
12-03-2015, 12:46 AM | #4 | |
The Older Generation
You can't post a WTB unless you are a Premium (paying) member. If you PM me your name & address I will send you one free of charge.... I would need to know which half you need. I think the terminals are available through NAPA but I can't remember the part number. LockDoc
12-04-2015, 09:10 AM | #5 |
LockDoc, Thanks. You are a truck saver!!! I'll PM you the info. THANKS.
Craig
12-04-2015, 03:17 PM | #6 | |
I will mail it out in the morning. LockDoc
12-02-2015, 11:46 PM | #7 |
One foot in front of the other
Try these guys
http://www.wiringharness.com/ |
12-05-2015, 12:11 AM | #8 |
Old member
Try these links.
http://www.bobschevytrucks.com/1967-...ess-36878.html http://www.partsgeek.com/catalog/197...al_switch.html Here is another. https://www.npdlink.com/store/produc...-143459-0.html
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
