12-02-2015, 06:24 PM | #1 |
1964 K10 Floorpan
Hi I am new to these forums.
I am restoring a 1964 Chevorlet K10 Shortbed. It has been converted it to a lowhump and had some rust on the hump. Any suggestion on replacement parts? |
12-02-2015, 07:32 PM | #2 |
Re: 1964 K10 Floorpan
12-02-2015, 08:07 PM | #3 |
The hump is original. I switched out the cab. All 4wd have a high hump so the cab is out of a c-10.
12-02-2015, 08:13 PM | #4 |
thanks for the floorpan lesson, but being you asked about one thing and showed a picture of another i went with the picture. btw i have a k10 and a c10 so i know the difference...
12-02-2015, 08:17 PM | #5 |
What year is your k10?
Posted via Mobile Device |
12-02-2015, 08:19 PM | #6 |
12-02-2015, 08:24 PM | #7 |
is yours restored?
12-02-2015, 08:49 PM | #8 |
12-02-2015, 08:30 PM | #9 |
not all had the high hump necessarily. the ones that used the 3 speed may have used the low hump.
ron |
12-02-2015, 08:48 PM | #10 |
12-02-2015, 08:52 PM | #11 |
12-02-2015, 09:13 PM | #12 | |
ron |
12-06-2015, 10:43 AM | #13 |
I'd cut out the just the cancer and make my own patch panel for it. I've had to do that several times on my truck where the cancer wasn't too bad or no replacement parts were available.
60 K20, eaton HO52, T221, SM420, Dana 44 closed 78 K20 Burb, 14 bolt, NP205, SM465, Dana 44 open 05 Dodge Ram 2500 5.9 Cummins 4x4 |
12-02-2015, 08:51 PM | #14 |
12-03-2015, 10:26 AM | #15 | |
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
12-03-2015, 01:32 PM | #16 |
12-05-2015, 11:55 AM | #17 |
I cut out the hacked up section and went bigger for ease.
12-05-2015, 11:57 AM | #18 |
pic of the finished project.
12-05-2015, 04:24 PM | #19 |
Where did you find the piece to replace it with?
12-05-2015, 05:29 PM | #20 |
12-02-2015, 09:28 PM | #21 |
This is my project so far. Since these pictures I have blasted the bed.
12-02-2015, 09:30 PM | #22 |
More pics
12-02-2015, 10:29 PM | #23 |
12-03-2015, 01:57 AM | #24 |
60-66 Nut
The easiest way to repair that is to find someone with a parts can that can cut out a patch piece for you. You might check in the '60-'66 classifieds here on the forum.
