Help! What AN fitting connects to fuel filter?
Stupid question but I can on find which fittings I need for my AN6 braided hose to connect in and out of my efi fuel filter.... I have pictures of fuel filter and hose
Re: Help! What AN fitting connects to fuel filter?
Hard to tell because the picture is blurry on my phone, but it looks like that fuel filter uses barb fittings. To use fittings you could get an AN to barb fitting and then use a small piece of fuel injection hose and clamps.
http://m.summitracing.com/search/par...-barb-fittings |
I thought about that but I was under the impression that barbed fittings and hide clamps wasn't sufficient for efi on Ls swaps because of the pressure...? If I'm Wrong that would be easy enough
I don't think it's the most ideal situation, but it's the only way you are going to use that filter. They make FI rated hose clamps and hose, so it is possible. Have you considered purchasing a fuel filter for the donor vehicle of your motor and adapting it? For example, my motor came from a 2003 Silverado and parts stores carry a fuel filter with female threaded fittings on either side which I am sure could be adapted to an fittings.
Thanks for your help, this is my first swap and I didn't even. Think of that, I will order one like that and then use the quick connect an fittings! Sometimes I need another point of view, thanks again Clemson
#6 | |
![]() Join Date: Jun 2012
I got a filter with NPT ends and then AN to NPT adapters for the fuel line. Here is a link to the filter.
http://www.spiderautomotive.com/70160.html
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
