Question about rad hose.
I am close to firing my 89 cummins suburban.
I had been waiting for manifold adapters to run a 24 valve manifold on my 89 12 valve. They are done! I have almost everything set up but I dont know what to do about a lower rad hose. Im runnig a 89 cummins in a 89 burb with a rad from a 454. What have you guys used to make the tight bend. I have a factory cummins hose that I could make work but it would be a lot of cuts and joins. Thanks Keith |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: Question about rad hose.
On the 89 burb I did, it had a champion replacement aluminum radiator. I installed the lower radiator hose from the dodge. Cut it to length at the rad side and it worked fine.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
Ya mine was no where close to fitting. I ended up using a later cummins lower hose. cut three inches out of the center built a alunimium bung at work to re connect it. worked out nice.
