Old 12-07-2015, 06:16 PM   #1
70inbville
tie rod end fitment
Will a 2004 tie rod end fit a 70 c-10 spindle? I want to convert to power rack and pinion and dang if I can find dimensions for a tie rod end to compare the two. I hate the idea of drilling a new spindle to use a heim rod end and a bolt, just trying to find another way to skin this cat!
Thanks,
Chip
70inbville is offline   Reply With Quote
Old 12-07-2015, 08:37 PM   #2
PGSigns
PGSigns's Avatar
Re: tie rod end fitment
I am sure it is a bigger taper like the 73 and up are. Any good machinist should be able to measure the taper and tell you if you have enough meat to bore your spindle to match.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-07-2015, 08:58 PM   #3
70inbville
MOOG dimensions for the 2004 tre is .630 at the bottom and .483 at the top, I cannot find what the 70 is anywhere. does anybody have these or a mic that can get them?
Old 12-07-2015, 09:07 PM   #4
PGSigns
PGSigns's Avatar
You need one more measurement to determine the taper and that is how far apart those two measurements are. You can have the same numbers but if they are not the same distance apart they are not the same taper.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 12-08-2015, 12:03 AM   #5
70inbville
Thanks for the info! my search continues.......
Old 12-08-2015, 06:06 PM   #6
mild68
mild68's Avatar
The tool a machinist will be familiar with is called a Morse taper reamer.
https://www.google.com/search?q=mors...mHAX8Q_AUIBygC
mild68 is offline   Reply With Quote
Old 12-08-2015, 09:04 PM   #7
PGSigns
PGSigns's Avatar
Not all tapers are standard morse tapers. Couple of the tapers used are 1.2, 1.5 and 2.0 inches taper per foot. for tie rods. Once you know the taper, then you can set up in the mill and ream to the correct depth of taper. Some tie rods may be the same taper just the depth of taper is different. So the one made with more depth of taper wont fit in the hole for the one made with less depth of taper even though the taper is the same.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
