TH400 issues
Ok so I have a 1970 c10, mild build small block with a th400. So with the gear selector in D (drive) when I'm in wide-open throttle from a dead stop it shifts from 1st to 3rd when it should be hitting 2nd. But if I put the gear selector in second from a dead stop and floor it, it shifts into second just fine and barks the tires, and holds 2nd til I shift into 3rd.
Any ideas? I was about to bring the truck to a tranny shop to get my much needed stall converter (which I'm so excited about, thanks you guys for steering me that direction) and told the guy over the phone exactly what the tranny is doing as explained above, and he says I'm lacking vacuum because of the big cam, and need a vacuum boost canister. I know he's not just trying to sell one because he doesn't even carry them or install them. He quoted me 525$ for a 10" race converter built local with billet parts and is comparable to high end Coan converters. And another 500 to remove my tranny, inspect, and re-install with new converter. I'm not a tranny guy, but I do know th400 is an awesome tranny and strong as heck. Can anybody offer some insight and ideas for what to do next? For anyone reading my head and cam combo thread, I decided to take your word for it and leave the motor alone and focus on these obvious issues, so this is where I'm at |
![]() ![]() Join Date: Sep 2008
Re: TH400 issues
Why not just put a temp. vacuum canister on it and see what happens?
Re: TH400 issues
Re: TH400 issues
Any transmission gurus have ideas?
Re: TH400 issues
A 10 inch converter is gonna be mighty loose for the street. I had one in my Chevelle and it would flash about 4500 RPM, but that was behind a big block motor. You had better make double sure you put on a good trans cooler cause that converter could cause the trans to get hot.
Re: TH400 issues
Do you have the electric kick down hooked up and is it working. The connector on left side of the trans should have power when at full throttle
![]() Join Date: Dec 2013
Re: TH400 issues
adjust the modulator valve ,Pull the vacuum hose there should be a small flat head screw adjust 2 rotations to the right and check ,It's not the best correct way to change shift points but it works ,also you would be better served by using a B&M governor kit to change shift points and /or a shift kit . You may want to rethink the whole "race" converter change for street use your just not pulling anywhere near the HORSE POWER to warrant a 10 inch higher stall converter .
![]() http://www.ebay.com/itm/TURBO-HYDRAM...-/320226822325 Just a note WIDE OPEN THROTTLE from a dead stop only lasts so long before you get LOTS of little metal pieces and an oil slick under your truck . I just read thru some of your threads and I understand it's tough to build a truck with 2 young kids and living in an apt . Maybe buy a nice house with a 2 car garage for your family to enjoy and then you'll have the space to buy all the tools you'll need build your truck and go as fast as you want ? farming out performance work gets real expensive real fast ! Last edited by Grumpy old man; 12-08-2015 at 09:57 AM. |
#8 | |
Re: TH400 issues
It is a bummer about the apartment. I think waiting on the motor work is a wise decision and I'm glad I asked because id be spending 3400 bucks on a head and cam install right now had I not. But, I do want the truck to at least run good so I can enjoy it now, and my Fiance and daughter really miss going for rides in it too. As it sits, the truck needs a new gasket on the trans pan because its leaking, and with the cam being the way it is, I think a stall converter would make it much more drivable (its a bear at stop lights) and Id make good use of the power I already have. As far as what kind of converter, I asked of couple guys on the site and a 2500-2800 rpm stall is the general consensus for street/weekend driven truck. I don't know the difference between a 10" and 12" converter, I just know that I need a tranny cooler for sure, and would like to get ABOUT 2800rpm stall and have a nice converter that I don't have to replace later with a better one. |
Re: TH400 issues
Just my opinion but buy your young family a nice safe home before wasting money on trying to make a long bed 45 year old truck go fast, their only young once and time flies by so fast you'll wish you spent more time and money on them than an old truck . you have plenty of time to invest in a cool truck later after buying a home you don't have plenty of time to invest in your young families future .rent is gone forever ,Mortgage payments mean you're buying something and will get it back in the long run .Take it from a grumpy old man you can't get back the time you spent playing with guy toys instead of kids and their toys ...
#10 | |
Re: TH400 issues
#11 | |
Re: TH400 issues
Anthony |
Re: TH400 issues
VA home loan is in process and we got approved yesterday so were shopping for a house now. The down payment is secure, this truck money is just what I set aside after all the important stuff has been taken care of. Theres just not much in the truck budget is all haha
