12-10-2015, 02:31 PM | #1 |
Th350 to 700-R4?
Truck is an 84 c10 swb with a 305 v8 4 barrel carb th350 transmission and I may be parting the 90 suburban and just wondering if I can use the 700 r4 without any modifications? Thanks in advance.
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me. Don't mess with my truck, my momma or my money...not necessarily in that order. ©Stand for something or fall for anything. [LIST][*]'98 Bourbon St. Brawl ©2010
12-10-2015, 02:34 PM | #2 |
Re: Th350 to 700-R4?
The crossmember will need to go back, you'll need a shorter driveshaft, you'll need some way to control lockup and connect your TV cable, you'll probably have to monkey with linkage also.
12-10-2015, 03:08 PM | #3 |
12-10-2015, 03:15 PM | #4 |
A 700R4 is physically longer than a TH350, so that's true regardless of wheelbase. Fortunately Chevy made these trucks with 700R4's so the t parts exist
J.R. Link to Daryl's build, http://67-72chevytrucks.com/vboard/s...10#post8443010 Link to my Youtube channel with build info, https://www.youtube.com/thedrivewayengineer |
12-10-2015, 07:33 PM | #5 |
Actually, no difference in driveshaft length if your TH350 is original to the truck. Car TH350"s are shorter by 3".
You will have to move the cross member back. |
12-10-2015, 10:14 PM | #6 |
Will the thm350c vacuum switch on the firewall that controls the lock up converter work with the 700r4? In other words, if your truck was originally equipped with a turbo 350c, will the 700r4 work with the 350c connections?
12-12-2015, 03:04 AM | #7 | |
I wasn't sure if all trucks got the 9 1/4 tail housing. Good to know! Natedogg, I have no idea, but I doubt it's that simple.
12-10-2015, 02:48 PM | #8 |
Thanks.
12-10-2015, 02:50 PM | #9 |
If you're parting the Suburban anyway, it will have almost everything you need
