Old 09-18-2003, 02:26 PM   #1
1971Stepside
Almost Satisfied
1971Stepside's Avatar
New Question! What 6cyl do I have
OK, sorry guys but the 68 needs new plugs/wires etc. Problem is I don't know what size 6 cylinder it is. Anyone know. I was able to get these numbers off the block 392-1968. I couldn't read the he ones by the carb, but they started out with 392 as well. I hope that is enough to go on for someone.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 09-18-2003, 02:29 PM   #2
zyggy72
Can't kick the addiction!
To me, it looks like a 292 but don't take my word for it.
zyggy72 is offline   Reply With Quote
Old 09-18-2003, 02:34 PM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
292 will have taller pushrod covers than a 250. It will also have the fuel pump located differently (either behind or in front of motor mount, can't remember). This is of little help but if you measure covers and descibe location of pump, maybe someone can fill in details.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 09-18-2003, 02:35 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
Also, if 292, it should be listed on your glovebox option sheet.
Old 09-18-2003, 02:39 PM   #5
1971Stepside
Almost Satisfied
There is nothing listed on the glove box sheet other than moulding, powerglide, and about four other things. Nothing about the motor. So, does that mean it is a 250? I'm pretty sure the pump is in front of the motor mount.
Old 09-18-2003, 02:40 PM   #6
CPNE
Resident Curmudgeon
CPNE's Avatar
250. Trust me...
Old 09-18-2003, 02:46 PM   #7
1971Stepside
Almost Satisfied
OK, CPNE thanks. They said the plugs for the 292 had extended tips and I wasn't sure which ones to get.
Any idea on the gap for the plug?
Thanks again.
Old 09-18-2003, 02:54 PM   #8
CPNE
Resident Curmudgeon
CPNE's Avatar
.035 with points, .045 with HEI
Old 09-18-2003, 02:57 PM   #9
dubie
dubie's Avatar
easiest way to tell is look at the motor mounts. The 292 is mounted on offset mounts while the 250 is mounted on parallels.
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 09-18-2003, 03:24 PM   #10
JJR
JJR's Avatar
Just curious, Is that an air pump on the upper drivers side? It doesn't look like a PS pump.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 09-18-2003, 03:32 PM   #11
Hooter
My other Love
Hooter's Avatar
the defineitly is an air pump on that beast, how is it for torque?
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 09-18-2003, 04:45 PM   #12
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
I agree it looks like a 250 to me too.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 09-18-2003, 04:50 PM   #13
1971Stepside
Almost Satisfied
Motor mounts are not offset. The motor has a smog pump on it. Alt is mounted under it (where PS normally is).
Thanks guys. I'll put the new plugs/wires in tonight. The wife wants to take her out cruisin tomorrow night!
Old 09-18-2003, 05:00 PM   #14
72shorty
Opened my hood, yep, looks the same. I've got a 250.
Douglas King
Independence, MO
72shorty is offline   Reply With Quote
Old 09-19-2003, 06:30 AM   #15
'68OrangeSunshine
'68OrangeSunshine's Avatar
If you look at the numbers & letters stamped on the machined pad just behind the distributor, you will see 2 or 3 letters. These letters can be run against a list in the LMC catalog index. It goes by year and displacement. '68 250s run like:TA, PF, TE, TT, PV, PW, TF, TC, TD, PX, PC. That listing is by no means written in stone. It does not correctly list my '68 292, "XAE" I have to dig deeper for that. Original owner's warranty -exchanged motor? XA and XE were used in '69 for 350s. This ain't no SBC.
HTH
Old 09-19-2003, 09:32 AM   #16
1971Stepside
Almost Satisfied
Thanks all. I changed the plugs and wires last night with no problems.
