12-23-2015, 05:03 PM | #1 |
LS or old school?
hey there guys/gals. I have a 1994 chevy shortbed 2 door truck, and Im taking the TBI engine and trans out, And I wanted to know if I should go with a stock junkyard LS or I already have a re machined new 355 with 2.02 heads from an early 80s truck and the heads came from a camaro.
I was debating an LS styled engine because I want DECENT fuel economy and good power, but I already have the 355 just begging to be put in it. If I did the 355 I would put a FAST EFI system on it, and it would have a 4L80 with Overdrive anyway. so my real question is, would the 355 with overdrive and efi be able to compete at all with a junyard stock 5.7 LS style engine? thanks everyone in advance |
12-23-2015, 08:08 PM | #2 |
Re: LS or old school?
I'm assuming you'll be using the efi on the ls? For me if I had that choice, I'd go ls for sure. Just stock I'm sure it'll outperform the 355 your thinking of putting together. Is the block from a 80s truck and the from the camaro, kinda confusing how you wrote it. Anywho old school stuff is fun but a mild 355 couldn't touch a ls imop.
1979 Sierra Classic Heavy-half 1996 Silverado x-cab "the daily" |
12-23-2015, 10:00 PM | #3 |
Old school for ease of workmanship.
LS for modern technology and better fuel economy.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
12-23-2015, 10:25 PM | #4 |
12-24-2015, 12:36 PM | #5 |
yeah sorry the block is from probably a late 80s truck, and the heads are from an early camaro. thanks for the reply
12-24-2015, 12:58 PM | #6 | ||
"I ain't nobody, dork."
"Camaro" heads means nothing. It could be any kind of head.
You can get decent fuel mileage out of either. Depends on how you tune and your driving style. Gary
12-24-2015, 01:02 PM | #7 |
I would go LS for sure. Probably wouldn't bother with the first gen 5.7ls I would find a 5.3 myself. The ls might actually be cheaper by the time you buy the fast fuel injection and the controller for the 4l80 in the older truck. The Ls with a cam upgrade will run circles around a 355 in both power and mileage.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
12-24-2015, 01:19 PM | #8 | |
I suppose your right, The 5.3 I heard pretty great things about it, but im running 36 inch tires and 3/4 ton suspension and diffs, so maybe something a bit bigger, I once had a 6.0 HO, maybe I can find one of them. thanks |
12-24-2015, 01:57 PM | #9 |
Don't get worried about the cubic inches with the ls engines. Most 4.8's are making more power than a cammed 350. The 5.3 is more than capable and will get decent mileage. The 6.0 is a tad more thirsty and obviously will make more power but the 5.3 can easily make 400-450hp with doing a lot of work to it. The 6.0 will be a lot easier to find with a 4l80e already attached though. Whatever you get make sure you get everything. The accessories, wiring and computer. The little stuff will eat you alive at the auto parts store.
12-24-2015, 02:14 PM | #10 | |
12-25-2015, 12:40 AM | #11 |
Id not run 2.02 heads on the street with unleaded fuel. They crack between the valves.
You need to run Duralt lead additive, which may not be made any more. 1.94s are big as I run, for the last 40 years or so.
Happy as a pig in mud |
12-26-2015, 12:06 PM | #12 | ||
2.02's with hardened valve seats are just fine on the streets.
Gary
12-26-2015, 01:23 PM | #13 |
Registered Truck Offender
Ya know, this hybrid thing is really starting to intrigue me. I'm not sure I can justify the one-off pieces and the cost,,... well..... yet.
I think I'm going to have to build one, put it ion a dyno and see what the $ per pound of torque ends up. The LS power and reliability in a standard tried and true SBC bottom end I wouldn't do a carburated version for anything but a drag motor,, but the possibilities of a stock LS EFI top end on a 4" stroke SBC with something like the AFR mongoose heads just gives me a tremble in the knees.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
12-26-2015, 03:24 PM | #14 | |||
Gary
12-28-2015, 10:49 AM | #15 | |
I assume there are LS swap headers for a square body out there ?? edit; I see 2wd swap headers, they're a little salty but not a game changer.
Tim K. 84 K30 srw Silverado 454 auto 85 C20 350 C6P auto flatbed 94 K1500 lifted shortbed 350 4 bbl NV4500 Last edited by 68post; 12-28-2015 at 11:16 AM. Reason: no |
Tags |
engine swap |
