12-24-2015, 03:51 PM | #1 |
1970 adding offset air cleaner need a couple parts
I,ve got most of the parts necessary to install my offset air cleaner for my booster install except 2 pieces. if anybody has them or know where I can get them would you please contact me ?
1st part the "rubber" hose that goes from valve cover to spacer on top of carb. 2nd part needed, the hot air pipe that goes from manifold area to air filter housing. seems the non offset pipe is different that the offset air cleaner pipe. all help is greatly appreciated. highest regards bob
I BELIEVE IN JOHN 3:16 |
12-24-2015, 04:14 PM | #2 |
Go Pack Go!
Re: 1970 adding offset air cleaner need a couple parts
You might have better luck on the parts board. I attached 2 pics that shows the heat riser for reference. I sold this several years ago, so it's not available for purchase.
12-24-2015, 11:01 PM | #3 |
thanks, I knew the heat riser stuff was different. I might have to fab it up. hope not as I like original mostly
