Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 12-27-2015, 10:42 PM   #1
davepl
davepl's Avatar
Help buying a towable Whisperwatt generator
I'd like to buy a Whisperwatt generator for my house. I have 600A service so by code I would need a 150,000 watt unit. I don't plan to weld in the hot tub while baking a turkey, so I figure 70kVA should get me by.
There's one on eBay that looks promising, but it's been on there for a month unsold. The hour meter is broken, which probably doesn't help.
What should I be asking the seller? If it were a truck I'd look for a leakdown or at least compression test, but it's a John Deere 90hp diesel, which I know nothing about, and a genset that I know even less about.
http://www.ebay.com/itm/MQ-Multiquip...torefresh=true
My plan is to have the 600A transfer switch installed at the house and then park this beside it, wire it to the input lugs, and manually throw it over when I need to. I've opted to go diesel because we're in a major earthquake zone and I don't think it's wise to rely on natural gas lasting long after a seismic event.
Thanks for any guidance!
- Dave
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-15-2016, 07:03 PM   #2
truckdude239
truckdude239's Avatar
Re: Help buying a towable Whisperwatt generator
What in the world are you running? I dont even think i have a 600 amp service at work well i might i do have 2 480 volt services coming in but wow . You shouldnt have to install that big of a genator a standard genrac whole home should cover you.
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 02-15-2016, 07:40 PM   #3
davepl
davepl's Avatar
Nope, code is that load shedding is automatic and that your generator can run the entire service capacity. Might be different in your state.
I don't plan to weld in the hot tub while my wife is cooking three turkeys and drying 4 loads of laundry, but code is code.
600A service is a killer. Going from 200A to 400A doubles the cost of things and to 600A more than doubles it again.
You can pick up a 200A transfer panel at Home Depot for about $300. A NEMA 4R Service Entry 600A Transfer Switch (even manual) runs over $8,000.
Old 02-16-2016, 03:06 PM   #4
_Ogre
_Ogre's Avatar
any transfer switch can be wired to a separate panel that only feeds critical circuits
i run my 2000 sq ft home on a 5200 watt generator when the power goes out
of course i'm all gas and have never tried to fire up the ac in the summer
shop air compressor timer
Old 02-16-2016, 07:20 PM   #5
davepl
davepl's Avatar
Nope. If you disagree, send me a link to one you think works with a 600A lug.
Old 02-16-2016, 09:21 PM   #6
_Ogre
_Ogre's Avatar
you asked for help, not me. if you just want to argue find somewhere else to do it
hospitals use big emergency generators, but not big enough to run everything in the hospital
they have separate emergency panels that feed critical circuits
any home depot will have a 20 circuit panel, feed it as a sub-panel with a 60 amp breaker
move all your important can't-do-with-out circuits to the sub panel
install a 60 amp transfer switch in between, buy a 15000 watt generator
that's how it's done
no need for a 600 amp anything
Old 01-15-2016, 07:06 PM   #7
drfloyd
What are you doing in your house, running a steel melting pot? I have a 25 KW PTO unit that I drive with my 75 HP John Deere tractor PTO and it runs my entire house. I have a 400 Amp service and under normal operating conditions I may have 30 to 50 Amps of load on it. But I am a firm believer in the more the merrier. Just remember, that 90 HP diesel burns a decent amount of fuel.
drfloyd is offline   Reply With Quote
