Old 12-31-2015, 12:39 AM   #1
AASmedic
AASmedic's Avatar
Another Height question
Good day all, I know this has been asked many, many times but I cant seem to find it. I am looking to find the stock height of a 72 K20. I am thinking of installing a 2" lift but want to know where I am starting from. I know that the original springs are still in the truck and they are sagging badly (front is about 1 inch from the bump stops). Also, any recommendations on front and rear leaf springs and if I need to change out the pittman arm or not. Thanks for the help.
AASmedic is offline   Reply With Quote
Old 12-31-2015, 01:12 AM   #2
lutjanid
Re: Another Height question
I'm also interested for purpose restoring stock ride height.
lutjanid is offline   Reply With Quote
Old 12-31-2015, 01:27 AM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Not exactly what you were looking for, but a little info that may help.
Many years ago my '72 K20's front springs were sagging. I measured 7/8" to the bumpstops. Bought 2 1/2" Skyjacker Softrides and after installation I had 3 3/4" to the bumpstops, so about a 2 7/8" increase over the sagging OEM springs.
Couple of things to note: No need to replace the pitman arm with 2 1/2" springs. Brake hoses are also long enough. But the shocks are too short. Use stock rear shocks up front, they are the right length extended and compressed.
The kit I got came with rear blocks but I never used them. Truck sits nearly level, has maybe a very slight rake with the front just a tad higher than the back. I got used to it years ago and I like it that way.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 12-31-2015, 01:37 AM   #4
kwmech
On a '71 I had years ago, I took the front leafs to a spring shop and had them rebuilt with an additional leaf. Still laid almost flat, really good smooth ride and they never sagged while I still owned the truck. I ran the springs for just about 10 years and over 100k miles.
Old 01-02-2016, 10:45 PM   #5
AASmedic
AASmedic's Avatar
Thanks for all of the input. I am thinking that the skyjacker will be the direction I take. Can't wait to get it installed and get my new "old" wheels and hubcaps on there.
Last edited by ETsC10; 01-05-2016 at 04:30 PM. Reason: Removing non-supporting member for sale ad
Old 01-04-2016, 07:33 PM   #6
El Dorado Jim
I also used the skyjacker lift springs on my 72 K20, love the ride, used the springs in the front, blocks in the rear, and skyjacker shocks all the way around,I also used U-bolts , I had made at a spring shop, they come up from the bottom, with plates on the top from a 74 chevy pickup....don't like the square u-bolts that point down....I have a corporate 14 bolt from a 74
El Dorado Jim is offline   Reply With Quote
Old 01-04-2016, 11:49 PM   #7
AASmedic
AASmedic's Avatar
Thanks for the input. I ordered the lift today. Hopefully my wheels will be back from powder coating this week and I can get everything set up.
