Aftermarket connecting rods???
Why are most performance aftermarket connecting rods .025" longer?
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
meowMEOWmeowMEOW
Re: Aftermarket connecting rods???
IIRC its to have the piston be 0 decked (piston even with block deck).
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
The stock deck height is .025"?
Fabricate till you "puke"
I will take a shot @ the ?....speaking from gen I experience (mostly), the pistons are generally about .025 below the deck. These engines, ran a factory gasket, in the range of .015- .018... (.040- .042 on the deck). This made a nice 'quench" figure....rebuild, the pistons are .025 shorter, & if you compound that with a .038 gasket, it don't take long to figure that you have crap for quench? The stock pistons on my 5.3 LS, are slightly positive deck (factory)! however, I understand that the replacement pistons, on the overbore are slightly shorter? If you are seeing a longer c to c on the rod, it may compensate for this....so you can still run the thick multi layer gasket , without decking the block
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
