01-04-2016, 06:57 PM | #1 |
62/63 spindles
what is the difference between 60-62 spindles and 63-70 spindles?
Scott 63 C10 Stepside 230 1bbl Saginaw 3 spd |
01-04-2016, 07:26 PM | #2 |
67-72 parts collector,…
Re: 62/63 spindles
ball joint and tie rod taper sizes,... since the 60-62 were designed for the torsion bar front suspension a-arms.
01-04-2016, 07:38 PM | #3 |
Re: 62/63 spindles
How about the brake shoe anchor bolt? I just got a disc brake kit for my 63. The hold down bolt at the top of the spindle for the anchor is 5/8 fine. The bolt with the kit is 3/4 fine
Top hole
Scott 63 C10 Stepside 230 1bbl Saginaw 3 spd Last edited by scott657; 01-04-2016 at 08:13 PM. |
01-04-2016, 07:46 PM | #4 |
Re: 62/63 spindles
Brake "shoe" anchor bolt?
On a disc brake spindle? I'm not following you.
01-05-2016, 02:10 AM | #5 |
60-66 Nut
Re: 62/63 spindles
I believe he bought the kit to convert a stock '63-'70 spindle to disc brakes. It comes with a bolt on caliper bracket that utilized the top brake anchor pin hole and one of the lower steering arm bolts.
01-05-2016, 06:31 AM | #6 | |
Re: 62/63 spindles
I see that now. Doesn't that kit make you switch to chevelle rotors with the 5x4.75 bolt pattern?
01-05-2016, 11:31 AM | #7 |
Re: 62/63 spindles
yes, it seems my spindle is an oddball, nothing a sleeve and a bolt can't fix
01-05-2016, 12:50 PM | #8 | |
Re: 62/63 spindles
These use 71-87 HD 5x5 rotors and calipers, like the 63-70, 71-72, and 73-87 trucks use. To me,... this is a better option than converting to 5x4.75" bolt pattern with the stock drum brake spindle.
