09-19-2003, 02:59 PM | #1 |
Designated A-hole!
Exhaust manifold?
Got a deal on exhaust manifolds. They are used, but they look like new so I plan on replacing both of my old ones.
Question 1. What should I paint them with to keep the rust to a minimum? Question 2. What do ya'll think about using brass studs on the collector. And if it's a good idea, where could I get some? Thanks, Krue
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
09-19-2003, 03:01 PM | #2 |
Resident Curmudgeon
I used high heat manifold paint from NAPA. Flat back.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
09-19-2003, 03:09 PM | #3 |
71 DELUX
Good results with that paint from Napa? Picture maybe?
09-19-2003, 03:12 PM | #4 |
Resident Curmudgeon
I need to get some pics of the project here soon. I like the way it looks and it holds up well as I've done it in other trucks. I think it looks good, especially if you engine is the old boring chevy orange.
09-19-2003, 03:39 PM | #5 | |
CCRider
Re: Exhaust manifold?
Brass studs...NO... Brass nuts...yes Take a good hard look at the studs before you install them...more than likely they need to be replaced. It is much easier to do in a bench vice than under the truck. If you have a torch you might get some of them out without drilling. If you don't have a torch, there is no chance in he!! of getting them out without drilling. If you grind them off and center punch them perfect you can drill them out without hurting the original threads....you can use heli-coils on the ones you do screw up...lol Any parts store that carries the "HELP" section will have the studs with the brass nuts.
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
09-19-2003, 03:41 PM | #6 |
performance coating
If you've got about $200, look in to ceramic plating or "cermacrhome". Good to 1100 degrees. Made my ram hours look like chrome. And the brass nuts are an excellent idea.
good luck, Scott
Silence is golden, duct tape is silver. - Scott |
