Old 01-07-2016, 03:31 AM   #1
72 C30 (Motorhome) question, broke down on the road...
Broke down, ya think 1972 Chevy C30 MH, 402BB, 4 speed manual, 42,000 original miles.
I'm out on a buy and drive adventure with my newly acquired rig. 300 miles into a 700 mile trip the clutch pedal has gone limp ( depress it and it stays on the floor) in Clovis NM. I got it going to a hotel by turning it off at stop light and starting it in gear, quite fun
It's midnight and 30 degrees outside so I didn't do any crawling around. I figured I'd ask y'all your thoughts so when I go out in the morning I will have a few ideas to check out. Is there a clutch master (slave) cylinder?
Thanks for the rescue
Old 01-07-2016, 07:24 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: 72 C30 (Motorhome) question, broke down on the road...
Sounds like the clutch rod linkage came apart . anything else seems like you would have noticed a change before it would just go to the floor .
You can use the LMC truck catalog to see a picture of the linkage set up .
Old 01-07-2016, 07:33 AM   #3
hamjet
hamjet's Avatar
X2, either a cotter key fell out, or the rod fell out of the fork from having no spring to keep tension on it, or less reason, a rod broke..
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 01-07-2016, 07:50 AM   #4
undertaker72
undertaker72's Avatar
x3 and also could be a clip holding the throwout bearing fork to bellhousing , unless someone changed the clutch system it should all be mech linkage no hydraulics
undertaker72 is offline   Reply With Quote
Old 01-07-2016, 08:43 AM   #5
chiefcfd
chiefcfd's Avatar
I had a clutch pivot ball break off years ago on a '72 C-10. Maybe you can get lucky and it's something simple.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 01-07-2016, 10:14 AM   #6
Yeah, all that. It sounds like between the pedal and clutch itself, for sure. My vote would be linkage came apart due to cotter pin. I hope you got a good night's sleep and the weather isn't too bad. Good luck with getting a part. I wonder what members are near Clovis.
Old 01-07-2016, 11:16 AM   #7
Thanks y'all !!!
The nut on the linkage rod backed off. Semi fixed, enough to get going.
Old 01-07-2016, 03:13 PM   #8
zeldman
zeldman's Avatar
Man..... Clovis, what a place to be stuck in...
Glad to hear you didn't lose the rod and assorted pieces that go with it.
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
Old 01-07-2016, 08:33 PM   #9
Clovis
Made it home, man that 402 is a beast of an engine. Ran between 60-70 and got 10 mpg.
Thanks again everyone, this site never ceases to exceed my expectations.
Old 01-07-2016, 08:59 PM   #10
70STOVEBOLT
70STOVEBOLT's Avatar
Let's see this rig!
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 01-07-2016, 10:13 PM   #11
Originally Posted by 70STOVEBOLT View Post
Let's see this rig!
Old 01-07-2016, 10:59 PM   #12
cooperhw
cooperhw's Avatar
Wow. Dejavu. Looks like Homer's long lost younger brother huh?
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 01-07-2016, 10:20 PM   #13
Billhilly
Billhilly's Avatar
Coooooooooool!!
1972 K2500 Long Box
400/350
Billhilly is offline   Reply With Quote
Old 01-07-2016, 10:41 PM   #14
DeadheadNM
Carpe manana
DeadheadNM's Avatar
From Albuquerque (Rio Rancho)? Glad that went to a member! Love my 72 C30 BB motor home. Post up pics when possible: http://67-72chevytrucks.com/vboard/s...d.php?t=510789
Old 01-07-2016, 10:44 PM   #15
DeadheadNM
Carpe manana
DeadheadNM's Avatar
What are your plans for the rig?
Old 01-08-2016, 10:28 AM   #16
I'd really like to keep this and paint the cab white and lightly restore the interior/exterior to make it an original retro rig.
Problem is I have people already wanting to buy it.
Old 01-08-2016, 03:27 PM   #17
davepl
davepl's Avatar
Keep it for a year! If people want to buy it that quickly there will be others. Don't make a 700 mile roadtrip into just a flip if you can keep it a while and have some fun with it.
I assume you're staying in the truck, or are you staying in motels? I'd figure you could be sleeping in the camper as you go...
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-08-2016, 04:26 PM   #18
Dang sorry about big pics
