01-07-2016, 03:32 AM | #1 |
Can't find correct length rear shocks
Hey guys, got a 69 C10 with a coil rear end dropped 4/6. I'm running the hotchkis springs which have a pretty light spring rate in the rear. Rear shocks were at a pretty nasty angle so did lakeroadsters rear upper shock relocater which I'm happy with angle wise. I've attached his link so you can see what I'm working with and in case it helps anyone else out. Easy, well thought out, and works. Thanks lakeroadster
http://67-72chevytrucks.com/vboard/s...d.php?t=451200 Now it's time to find some new shocks since the old ones are seized (probably from the angle they were run at) and the incorrect length. I've looked up how to measure and I get 9" compressed, 13" static, and damn near 18" with the wheel just barely touching the ground extended. The po did some funky stuff but don't think he did a long travel rear end. Nonetheless I'm having some trouble finding a shock that meets those lengths or anything close. The truck was lowered 7.5 out back so I notched it. I figure I can limit the downward travel with a bigger bumpstop but the notch was a pia and I'd hate for it to be for nothing. And while I don't plan on necessarily jumping the truck, I do want to beat on it, and don't know if using the shock as a suspension limiter is the best idea. I've been looking through manf. pdfs at lengths and I'm lost. I know I'm not gunna find a shock that's 9" compressed with a 9" stroke but if you guys can point me in the right direction it'd be greatly appreciated. |
01-07-2016, 08:00 AM | #2 |
Re: Can't find correct length rear shocks
You cant go by the length with the rear hanging with out the shocks as the shocks a lot of times is what is holding the rear end when you jack one up. I would take your 13" static and ad 3 inches of travel and look for a shock.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
01-07-2016, 11:12 AM | #3 |
That's about the dimensions of a front shock for your truck.
01-07-2016, 12:25 PM | #4 |
You notched it enough that you have 4" of uptravel? That's more than I'd have expected.
I agree that you won't be able to get that much droop either. If you look at a single telescoping shock with ends for attaching to something, you can't have extended length double compressed length. I think a couple inches of downtravel would easily be adequate.
1973 C20, 350/350 |
01-08-2016, 04:20 AM | #5 |
SCOTI that made me check out front lengths and summit has some edelbrock ias's for just $20. Think at that price I'm gunna go for it. Just wondering if shocks at that price point are valved or tuned differently for front and rear? Guessing if they are they'd be way to firm. Or is it likely the same shock in a different length?
01-08-2016, 10:30 AM | #6 | |
